Proboat brushless esc and motor lot
  • roadrashracing
    • 1630
    I need to clear some more stuff out. This is all being sold together, all items worked when I used them, but might have a small flaw here and there. The top one I got from warranty from proboat, they said it was new but it was used. Just needs battery connectors. I had hooked a motor up to it a while ago and seemed to work fine. The middle speed contorl I have used a lot, it is setup for the motor below, it has larger motor connectors, you will need your own battery connectors, the on-off switch went bad so I had to soider the wire together, the rx connector is also bad but still plugs in. The motor ran fine, it just has a little bit of expoxy stuck to it from a project. The middle speed control and motor are about a year old, un sure of the other. Asking $65 shipped for everything, lower 48 states only please.
  • HYDROJERRY
    • Jan 2010
    • 2709
    I only need one of the esc's ill give 25.00 for the one with the switch still on it if your sure it works properly,,,
    • cdlowe30907
      • Oct 2010
      • 19
      How much for the good esc and motor shipped to 30907? Does the esc have reverse? What kv is the motor? Want to put in my Shockwave 26. Let me know. Thanks
      Shoot me a PM and let me know.
      • roadrashracing
        • 1630
        I ran it in a boat once last fall and it seemed to work fine.
        • roadrashracing
          • 1630
          would rather sell the set together.
          • dannybj26
            Going fast on the 836
            • Sep 2011
            • 333
            how much for motor only
            losi scte full carbon,Hpi baja 5te,Hb tcxx
            Enforcer gator full mod 30cc
            Rico 31
