Hyper Performance Bullet Drive Outboard
  • Darin Jordan
    • 9446
    Hyper Performance Bullet Drive Outboard, complete package with coupler and FE motor adapter. I only used this for one race weekend on my LeeCraft/Geraghty tunnel that I recently sold.
    $100.00 shipped in the USA.
    Darin E. Jordan - Renton, WA
  • Darin Jordan
    • 9446
    Sale Pending on RRR....
    • Darin Jordan
      • 9446
      I haven't heard back from the guy on RRR, so this outdrive is still available at this point.
      Great Deal, guys...
      • rcbidder
        • 1680
        Will this fit the Proboat Stiletto?
        Will the mounting holes line up?
        • Darin Jordan
          • 9446
          It can fit, but the existing mounting holes in the Stiletto won't work.
          You'd have to get this positioned, then drill the transom and tap it for the correct size fastener. (there is an metal plate backing up the transom in the Stiletto that drilled and tapped for threads for the existing mounting, so drilling a new pattern is pretty easy to do.)
          The mounting base for the Bullet Drive is considerably smaller than the OS, K&B, or ProBoat mounting.
          • Meniscus
            Refuse the box exists!
            • Jul 2008
            • 3312
            What's the max diameter prop? Thanks.
            • Darin Jordan
              • 9446
              This will fit pretty much any diameter you want... there is enough clearance for at least a 50mm, and likely larger.
              I compared it to the ProBoat outboard, which I designed to handle at least 50mm diameter, and the Bullet Drive has even more clearance.
              Additionally, the cav-plate bolts on, so could be shimmed up even higher.
              NOT sure why you'd want or need to do that, but it can be done...
              • Darin Jordan
                • 9446
                This item is still for sale.
                • egneg
                  • 4759
                  Darin, I posted a reply on RRR.
                  IMPBA 20481S D-12
                  • Darin Jordan
                    • 9446
                    Gotcha... it's yours. I PM'd you the info.
                    • egneg
                      • 4759
                      Payment sent - thanks Darin
                      IMPBA 20481S D-12
                      • Darin Jordan
                        • 9446
                        Got it. I'll get this in the mail tonight or first thing in the morning. USPS Priority, so it'll get there quickly!!
