MHZ Micro Iceburg
  • mschaffer66
    replied
    $90 Shipped
    Leave a comment:
  • Browning
    replied
    Interested, pm sent ....
    Leave a comment:
  • mschaffer66
    replied
    Bump. Make offers.
    I'll also throw in a waterproof micro Traxxas servo.
    Leave a comment:
  • mschaffer66
    replied
    Getting warmer... :)
    Leave a comment:
  • mschaffer66
    replied
    Vroom...
    Leave a comment:
  • mschaffer66
    replied
    Copied from MHZ's site:
    Micro Iceberg
    Hull Type:
    Mini Catamaran
    Model:
    The Micro Iceberg is a semi-scale replica of an offshore catamaran. The V shaped pontoons provide uncanny cornering as well as straight-line stability. The three small steps allow high speeds. Propulsion can be provided by either one or two 400-class brushed electro motors. For the ultimate performance, one or even two brushless motors have been used with outstanding results. The craftmanship of this ultra-light epoxy-glass hull is jewel-like. The hull has a mirror-like gelcoat finish which does not require painting.
    Kit Contents:
    Light-weight epoxy-glass stronger than ABS-plastic or the heavier and weaker polyester-glass. Hull and hatch, with high-luster gelcoat do not require painting. Hull and deck are joined "wet-in-wet" for high strength seams.
    Technical Details:
    Length: 440 mm (17.3 inch)
    Length (overall.): 510 mm (20 inch)
    Width: 126 mm (5 inch)
    RC functions: Rudder, Speed Control
    Electric Motor Requirements:
    One Graupner 480 Race or 480 BB Race or Two 400 Speed
    or Brushless (one or two) Modell Motors Mini AC 1216/15
    Cell requirements:
    7 to 8 cells. For example N500AR or Sanyo AR 800 mAh or
    KAN950 or KAN1050 or 2s or even 3s lipo
    Competition Class: Mini Offshore
    Leave a comment:
  • JPriami
    replied
    How long and wide is it?
    Leave a comment:
  • mschaffer66
    replied
    Maybe you should build one
    Leave a comment:
  • blackcat26
    replied
    These are awesome little boats. Check out youtube and see for yourself. Very cool
    Leave a comment:
  • mschaffer66
    started a topic MHZ Micro Iceburg
    MHZ Micro Iceburg
    I just don't have time to build this little guy with building a 1:1 crawler so I'm going to put it up on here in the hopes that someone will give it the love it needs.
    The hull is in pretty good shape, there are a few nicks here and there, but nothing major.It is already set up for twins and I am including the 1/8" drive lines, some aluminum to make new stuffing tubes, some brass that I had planned on using to make a little hatch handles like on the Gieco boats, and of course the pair of micro struts from OSE.
    In the back the black marks are where I was going to mount my struts and stuffing tube. Only the rudder mounting holes and push rod are actually holes :)
    I'll let it go for $100 shipped to the lower 48. And not a dime less :) If it doesn't sell I'll build it someday lol
    Here are some pictures...
