FS Some ESC and UBEC
  • m4a1usr
    Fast Electric Addict
    • 2032
    For sale are a couple speedos and some UBEC's no longer needed.
    1st. is a Hextronik 120 amp ESC thats been sealed in DP270 and water cooling plates added to all 3 FET layers. I never used it for the intended build and its taking up space. I have a second one as well, not shown, that is also up for sale. Buy both and I will toss in the USB port programmer for this series. Its a pretty cool program because you can use your computer with the esc to run a motor. Allows bench testing. Has deans on the battery leads and 4mm bulltets on the motor side. Both sold
    2nd item is a HiModel GX200 ESC that has had a mini fan added to the aluminum cooling plate. These are opto coupled, no bec. Normaly these ESC are rated 2 to 6S. This one has 25 volt caps making it only a 5S in my opinion. But I have some new 35v rubicon caps to make it a 6S again that I will toss in if you want them. Never installed this in any hull, basicly new. Has 5.5mm bullets on both sides. SOLD
    3rd item is a KoolFlight 6 to 40 volt/ 3-5 amp UBEC. 6 volts out. Very robust units for A/C but works fine in our hulls. They are conformal coated making them water proof. Dont want a seperate Rx pack? Here you go to save weight. I have 2 for sale. $20 each.
    4th items are a couple Hextronik UBEC's. 6 to 23 volts/ 3 amp. 3 amp out. Both have been sealed in DP270 epoxy making them water proof. SOLD
    Thanks for looking.
    John
    Change is the one Constant
  • swampthing71
    • May 2010
    • 42
    I would like to get the Hextronics 120amp ESC from you (first one shown for $40. PM your paypal and I will send payment if you still have it.
    • syncronized77
      • Jun 2010
      • 277
      pm sent for the 2nd Hextronik 120 amp ESC u have
      Go Brushless or GO HOME
      • swampthing71
        • May 2010
        • 42
        Paypal sent. Let me know if there are any issues. Thanks.
        • Skipster
          • Apr 2009
          • 106
          I'll do the two
          Hextronik UBECs
          for 15
          Thanks,
          Skipster
          You can lie to mother Nature
          but You can not fool father Physics
          The more I learn, the more I know I don't know
          • lectriglide
            • 538
            I've been reading about the Himodels and want to try them out, so I'll take it and the add'l caps if still available.
            George
            • m4a1usr
              • 2032
              George
              Still available.
              John
              • lectriglide
                • 538
                Originally posted by m4a1usr View Post
                Still available.
                John
                Payment pending pp addy.
                • Mel279
                  • Dec 2008
                  • 857
                  hi m4a1usr
                  If I were to change the esc caps, is it possible to change using 50v caps and can use it up to 12s, if it rated only up to 6s?
                  Stiletto tunnel,EPV135 (53") twin cat, CT06"Spirit of Qatar", FD 47" mono, Twin Mini Cat 23.5"
                  • lectriglide
                    • 538
                    Payment sent for Himodel
                    • m4a1usr
                      • 2032
                      Originally posted by Mel279 View Post
                      hi m4a1usr
                      The ESC is sold but regarding your question, the FET's on the GX200 series are rated at 30vdc. You could add higer value caps (thats a smart thing) but you would still be limited to 7S max. The FET operating voltage is the limiting factor.
                      John
