FS: Apparition Hull and Hardware Cheap
  • bustitup
    • 3072
    Originally posted by sailr View Post
    Just run it like it is then if you feel it is necessary, try removing the foam. Careful. Those hulls are really thin! Easy to punch through it.
    yes this will be an experiment to TRY to get the foam out and see if it permanently stretched the fiberglass and in the end I will still run it no matter the outcome
    • bustitup
      • 3072
      any tracking number here?........
      • bustitup
        • 3072
        it arrived this afternoon
        the hull looks absolutley awesome and the bulges are not that bad.....they are four small bumps two on each side that are well far forward enough not to effect handling what so ever....I havnt decided if there even worth trying to fix them
        thanks for the deal V
        • AZpdljumper
          • Apr 2009
          • 98
          Is there any solvent that will desolve the foam and not hurt the fiberglass?
          Might try to desolve a piece of the foam that you chip off.
          My 0.2
          SV 27 , Mean Machine, Prince 26,Vac-U-Pickle
          • bustitup
            • 3072
            #35
            My 0.2
            So far I tried acetone....it doesn't do anything
            • befu
              • Aug 2009
              • 1064
              #36
              foam
              some of that foam will react/disolve when you try to use polyester resin on it. Why don't you mix up a gallon and just pour it in the hull and see what happens......
              I have a scrap piece of the spray foam downstairs from my micro cat project from last week. I will try a little bit of MEK on it and see if that does it. I will let you know in a little while.
              Brian
              • befu
                • Aug 2009
                • 1064
                #37
                Nope
                Nothing. MEKP barely touched it, not enough to disolve a hull full. Gas also did not. Now, gas on fire might work..... Video it if you try this!
                I split apart a 54" deep vee with expanding foam one time. Where it split the hull, I heated a butter knife on the stove and slid it in the split and the foam would melt away. Maybe heat a steel rod and stick it down into the hull and melt holes into the foam? Then you could start ripping it out.
                OOOORRRRRRR Just run it as is and have fun
