2014 West Florida Model boat club, Sarasota, FL
  • rdcracer
    • Jan 2014
    • 306
    #676
    I am going to try to get it ready for that race. Any help you guys can give on the build I would appreciate it. I found a couple of the motors new on Amazon.
    Blackjack 29. Deltaforce 33. Cheetah twin, Insane FE30
    1/10 1970 PaynPak, Aeromarine Jersey Skiff
    • ron1950
      • 3082
      #677
      id say sence u are going to have to be fast to get all the parts u will need now...strut ...rudder motor mount...motor ... right hand flex or decide if u want to use solid shaft....through hull fitting etc all the little stuff so u dont have to stop and order stuff ....
      • rdcracer
        • Jan 2014
        • 306
        #678
        What are the rules on the shaft. Does it need to be solid shaft? Once I get the kit I will order everything right away once I see exactly what I need. Is there anywhere I can see a listing of parts I need now online?
        Also does anyone have an extra drain plug for the Blackjack or Miss Geico 29 laying around from an old hull. I took mine out after I flipped last time and it fell off the table never to be seen again.
        • ron1950
          • 3082
          #679
          didn't know the 29's had a drain plug at least my old mg doesent....doesent have to have a solid shaft but has to have a straight stuffing tube from exit of hull to the strut....there are no lists that I know of...its the same as any boat build from scratch...u need at least one of everything....
          • R.J.S
            Racer
            • Apr 2012
            • 152
            #680
            Rich,if you haven't already,be sure to read T.C.'s 1967 Miss Budweiser build that's posted on RumRunners forum.
            Terry has scratch built 2 thunder boats from plans and is our local expert.He's mostly retired from the hobby now, but if you can hook up with him via PM,I'm pretty sure he'll be glad to "coach" you thru your build.
            JS
            • rdcracer
              • Jan 2014
              • 306
              #681
              Do you have a straight shaft on yours and is the straight stuffing tube solid from the hull to the strut?
              I am going to give it my best shot to get it done before the race. If not I am going to run LSO and P-mono anyway. I will keep you posted. I wish we could get more guys in our area interested in these. They just look so cool running and they look like they are fun to drive. Hairy in the turns.
              • rdcracer
                • Jan 2014
                • 306
                #682
                JS
                Thanks RJS for the info. Rumrunners is a bear to get registered on. It kept hanging up on the "Are you human" question and then I couldnt figure out what the squiggly words were.
                • ron1950
                  • 3082
                  #683
                  all three of mine are being converted to flex shafts hugh has one of each
                  • rdcracer
                    • Jan 2014
                    • 306
                    #684
                    Good I like the idea of a flex shaft over solid. For running counter clockwise do you run a different rotation on the prop?
                    • rdcracer
                      • Jan 2014
                      • 306
                      #685
                      I spoke with Mike at ML boatworks tonite. I changed to the 103 hull on his advice as he has a bottom plate for it that makes building easier. Havent decided on which boat yet. He is a really nice guy and very helpful.
                      • RayR
                        @SiestaKey.calm
                        • Jun 2007
                        • 1591
                        #686
                        Yes, reverse rotation cable and reverse rotation props.
                        The build by TC (Terry Cowger) on rumrunner is one of the most fully documented and detailed 1/10th scale builds ever. The resulting boat is simply incredible. It is under the build contest thread.
                        When you get signed up the post is here:
                        Just to peak your interest here are some pics from that build (yes those are inlayed Mahogany planks).
                        • ron1950
                          • 3082
                          #687
                          I tried to get tc to make driver turn head and wave but he wouldn't go for it
                          • R.J.S
                            Racer
                            • Apr 2012
                            • 152
                            #688
                            Don't forget to reverse motor rotation as well.
                            That beautiful Merlin V12 in TC's Bud was scratch built from wood!
                            • rdcracer
                              • Jan 2014
                              • 306
                              #689
                              I got the thread and signed up for the site but I am still waiting for the authorization email. I can look at the build but the pictures are locked and say I dont have authorization. I was thinking it was reverse it makes sense. I cant wait to start. I havent done a wood build i awhile. I built the Dumas Chris Craft barrel back and did the inlaid mahogany as well. It is a great look. I wish we could get more people interested in these hydros. They are really cool.
                              • rdcracer
                                • Jan 2014
                                • 306
                                #690
                                Can anyone help me with this. I signed up on the rumrunner.com website and got registered to check out the TC build but none of the pictures are visible. I cant even contact the admin to help I just get this message
                                rdcracer, you do not have permission to access this page. This could be due to one of several reasons:
                                Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
                                If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation Anyone have any ideas?
