Team Fembot (South Eastern VA)
  • Diegoboy
    • Mar 2007
    • 7443
    #271
    Cool. That V935/3 will be sweet on the Renegade (after it's cut to a V932/3)
    • Meniscus
      Refuse the box exists!
      • Jul 2008
      • 3312
      #272
      Speaking of Renegades...do you have that other prop laying around that I could try Diego? The one that led to your collision?
      Also, I want to see if I can use that pink foam and create another tub. I'm thinking about skinning with that other material. The only problem is, without paint, it will be the same color scheme as your new rigger. LOL
      Egneg, I haven't had the BJ in the water since that day at Loch Fembot. Just let me know when you want this prop back or if you have a use for it. I don't want you to think that I am holding it hostage (even though I am! LOL!). J/K
      • Diegoboy
        • Mar 2007
        • 7443
        #273
        The prop you refer to is the Y535, the one on Jeff's Vegas. Luckily, Egneg has prepared another for me. LMK when you want to test it out, I wanna be there!
        • Meniscus
          • Jul 2008
          • 3312
          #274
          It was a Y535? I don't remember that. Cool, I'm thinking about testing in your favorite spot in Newport News! LOL, J/K
          • Diegoboy
            • Mar 2007
            • 7443
            #275
            Just let me know when.
            • Meniscus
              • Jul 2008
              • 3312
              #276
              We'll have to arrange a meeting anyway so that I can "appropriate" that foam.
              • egneg
                • 4759
                #277
                Speaking of pink foam ... I have plenty if anyone needs some. I bought a 3/4" x 4' x 8' sheet and only used about a square foot. And Ben don't worry about the prop as I haven't run since then either.
                IMPBA 20481S D-12
                • Diegoboy
                  • Mar 2007
                  • 7443
                  #278
                  Egneg, How's that V932/3 coming? No rush at all, I'm just curious...
                  • egneg
                    • 4759
                    #279
                    I have it cut down, shaped, thinned, and now I'm in the process of getting it balanced.
                    IMPBA 20481S D-12
                    • Meniscus
                      • Jul 2008
                      • 3312
                      #280
                      Cool! I guess it can collect dust just as easily at my place, LOL.
                      Hey, how's that secret project coming? (the one you bought the ESC for?)
                      • Meniscus
                        • Jul 2008
                        • 3312
                        #281
                        Its official. Crankshaft is scored. Not bad, but it means I'm taking out the engine.
                        I have mostly disassembled after my diagnosis yesterday. Only have to do compression check to see if I'm doing the head as well with the rebuild. While I'm there, I'm going to do the clutch, resurface the flywheel, pressure plate replacement, throwout bearing, etc.
                        Meanwhile, while I'm freezing my butt outside working on the truck after dark...
                        (now accepting donations of pink foam for my CF rigger build) Thanks guys!
                        • Diegoboy
                          • Mar 2007
                          • 7443
                          #282
                          I told you I'd help with the rebuild...
                          ...and bring the foam too.
                          • Meniscus
                            • Jul 2008
                            • 3312
                            #283
                            Bring it on! I'm going to make every waking hour count! (minus time spent on OSE )
                            • egneg
                              • 4759
                              #284
                              Diego the props are ready!
                              IMPBA 20481S D-12
                              • Meniscus
                                • Jul 2008
                                • 3312
                                #285
                                Now that the prop is done, I have to say, I wanna be there Diego when you try that prop on the Renegade! I think it will be just what you are looking for.
                                Egneg? Are you still keeping that new project secret?
