Mar 7-9th, 2008 Az NAMBA Winter Warm-Ups
  • Flyguy55
    • 218
    Originally posted by SJFE View Post
    If I may stray off subject slightly. In regards to the tunnel class. If you ran an AMMO 36-56-1800 and Great Planes 45 amp esc(witch is probably the same as the sv) would that be a legal entry? The specs would still be the same. The only diffrence is the ammo is a 2 pole motor and the SV is a 6 I think.
    Thanks,
    Tom
    According to grim , the SV 27 motor is a spec. motor , not an Ammo
    Specs
    This is the AquaCraft Marine Brushless Motor for use
    with the AquaCraft Super Vee 27
    FEATURES: Direct replacement motor
    Brushless In-Runner design
    Pre-installed 3.5mm gold bullet connectors
    INCLUDES: One B36/56 Brushless Marine Motor
    REQUIRES: Installation
    SPECS: Length of can: 2.07" (53mm)
    Length including shaft: 2.8" (72.77mm)
    Stator length: 56mm
    Diameter: 1.42"(36mm)
    Shaft diameter: 5mm
    Must be a misprint . Hard to get a 56 mm stator in a 53 mm can
    Can measures 53 mm .
    Specs for the Ammo
    SPECS: Motor Diameter: 1.42" (36mm)
    Motor Length: 2.2" (56mm)
    Shaft Diameter: .197" (5mm)
    Shaft Length: .591" (15mm)
    kV Rating: 1800 rpm/V
    Weight: 10oz (283g)
    Input Voltage: 14.8-22.2V
    Max. Constant Current: 50A
    Max. Surge Current: 90A
    Max. Constant Watts: 1110W
    No Load Current: 1.9A
    • D. Newland
      • Dec 2007
      • 1066
      John and Bill-Do you have a preference as to which day to run the tunnel's?
      • D. Newland
        • Dec 2007
        • 1066
        Race site has been confirmed.
        Crossroads Lake in Gilbert, Az
        • SJFE
          • 4867
          I'd really like to make it. Goodle maps state 2,469 mi – about 1 day 13 hours. Thats some driving.
          • jfruge
            • 85
            I say Sunday for the OPC tunnels... I also say if we don't get any more SV27 sing ups lets just replace that class with the SV powered tunnels...
            Fun Fun!
            John Fruge Madera, CA !! bbyracing Call Randy for great service & prices!
            NEU, Castle, RC Lipos, and more!
            • Bill-SOCAL
              • 1409
              Doesn't matter to me. Pick a day, tell me when.
              I would recommend that the one constant be an ESC with a 45 amp max rating like the stock SV. Already people are wandering away from the idea of a true spec class. And there hasn't even been a race. The whole idea I thought was to have a number of essentially identical boats to run against each other. I must have misunderstood that point.
              Don't get me started
              • PatrickM
                • 154
                Ran my WOF with the SV27 power package for the first time today and am somewhat pleased with the results, but it does need some fine tuning...
                One of our goals at the Winter Warmups is, and has been, to put on a laid back, casual event to allow racers to test new combo's and setups for the coming season. The idea behind allowing racers to run something outside of a "one motor, one hull" spec is to learn how other products compare as well as to allow those who may not have the spec hardware to compete.
                We are not trying to set a precedent for future events or spec rule proposals, simply trying to be inclusive and maybe attract another entry or two. If a non SV setup is out of line performance wise, the issue will be addressed at the drivers meeting and a decision to allow or disallow the entry can be made by the racers.
                From my observations running the OB SV27 setup today, I tend to believe that the Aquacraft ESC is underrated at 45 amps, most likely just a nice round number that was picked for warranty purposes.... The tunnel was running at comparable to LSH speeds, but burning nearly double the mah used by the SV27 setup in my DH shovel.
                • jfruge
                  • 85
                  Patrick, that sounds good to me. I also think that if Tom is willing to dirve 2,469 miles to come join us he can run what ever he has in his tunnel! Closer to the spec rules the better.... but hay... if gets him run with us... bring it on!
                  This should be a great event!
                  I know I am counting the days.
                  • Dan Proulx
                    • Dec 2007
                    • 41
                    I'm thinking about entering LS OPC and Sunday would be my preference too.
                    Tony - regarding that package you sent me that was supposed to be ticking...I think you sent me the wrong one cause this one is only vibrating?
                    I'm not sure I want to open it.
                    Dan
                    • properchopper
                      rcgoatbuild@snotmail.com
                      • 7708
                      Dan
                      I'm cool with Sunday too.
                      Dan : Something musta' gotten switched ; kinda' explains why my girlfriend's been so grouchy lately
                      • RandyatBBY
                        • 3944
                        Dave and Pete Hi
                        Well I wanted to put in my classes for the WWU IV
                        Only have one question(right now) Can I run my SC26 with the Blacl Jack guys? Sounds like fun?
                        Friday:
                        LSO CH75 or Spectra
                        N-2 Hydro CH75 or Spectra
                        Saturday:
                        N-2 Mono CH75 or Spectra
                        P Sport CH75 or Spectra
                        Open Mono CH75 or Spectra
                        Sunday:
                        SV 27/Blackjack If the SC26 is allowed CH75 or Spectra
                        N-2 Sport CH75 or Spectra
                        1/8th scale CH75 or Spectra
                        I am not sure if I am gona wish I signed up for more but at my age 3 a day should be enough.
                        __________________
                        80 MPH + P Sport Hydro club Member
                        Randy
                        BBY Racing
                        • jfruge
                          • 85
                          Guys, how much per boat and when can we pay
                          Fun Fun
                          • Quietlee
                            • 198
                            Classes
                            Here's what I'm planning on for classes. All on Ch 84
                            Fri
                            LSO
                            Sat
                            P Offshore
                            P Sport
                            LSH
                            Sun
                            SV27
                            P Mono
                            N-2 Sport
                            Gonna be fun!
                            • D. Newland
                              • Dec 2007
                              • 1066
                              Thanks Randy and Lee for signing up!
                              Hotel and race fee information will be posted this week.
                              Race class list updated. SV 27 Tunnel happening on Sunday. Who's in??
                              • properchopper
                                • 7708
                                Re :
                                I'm in for OPC Tunnel on Sunday. [ will specify radio shortly] Another fine mess you've gotten me into !
                                BTW did I read correctly that LSO is allowing SV motors & SC's ?
