Ampba " ea outboard " question
  • rcboatmanwithkids2880
    • 348
    Hi Guy's ,
    Currently i am building a 32 inch tunnel hulled boat , that has an Outboard powered leg , i have 2x 2s 40c batts & 120 amp ESC . just trying to ascertain what motor is used in the " EA- Outboard Class " , i have my eye on an Ammo 36-50-2300 or UL1 36-56-2030 ...
    Any advice appreciated ,
    Brad
    Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
  • Scott T
    • 625
    Brad, EA allows any motor. However, you might want to check with your local club to see if they have any restrictions. What's the hull?
    Scott Tapsall
    Pine Rivers Model Powerboat Club - Facebook Page
    My Gallery
    • Kris Flynn
      #2 Bench Racer
      • 248
      Hey Brad,
      Most are going with the UL1 Motor, plenty good enough!
      Kris
        • 348
        Hi Guy's ,
        The hull is a Vantex that i have changed to outboard configuration , gave the guts of the original set up to my brother so he could put it into a project boat he sharing with his son . So i may buy the Ammo as it seems on specs it's a touch more powerful than the ul1 unit ( 60 amps ammo - 50 amps ul1 ?? ) , plus ammo has higher kv rating or would you still suggest the ul1 . The props i have are Octura x642 n x640
        Thanks Muchly ,
        Brad
          • 348
          pics
          Hi Guy's ,
          Attached a couple of pics of what state the project is at , just waiting for warmer months to finish painting ....
