NAMBA P-LIMITED Motor List - Pro Boat Motors NO LONGER AVAILABLE
    • 7277
    #121
    Should spec the shaft diameter as well as the wire gauge.
    • Doug Smock
      • 5264
      #122
      BUT it opens the door to some interesting possibilities for the more "experimentally inclined"
      It has been interesting to see the various combinations of frakenstators and modificated rotors that a dimension rule yields. And it's still early.
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • properchopper
        rcgoatbuild@snotmail.com
        • 6958
        #123
        My Enhanced Gaussian-Fluxdensityerator is on the way.......
        • Doug Smock
          • 5264
          #124
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • properchopper
            • 6958
            #125
            Here's a peek :
            • Doug Smock
              • 5264
              #126
              If it works out for you Tony I'll take two!
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • jaike5
                • 561
                #127
                fluxdensityerator, ? is that an upgrade from the Mr fusion fluxcapassator
                  • 9438
                  #128
                  Jeepers, I've got a pair of 2 pole 2300kv motors kicking around, rated at 1100 watts max. Cost me a whole $14 each on sale. Basically a Feigao knock off, 36 x 60, they are in a box if I'm desperate.
                  • T.S.Davis
                    • 6228
                    #129
                    The experimentally inclined could have been frankenstatoring all along. I didn't see any.
                    Most people just want race. Inventing some obscene abomination of a motor to beat some nuckleheads that you see all the time at every race you go to? Not likely.
                    Noisy person
                    • Doug Smock
                      • 5264
                      #130
                      Look what happened when they were given a dimension to build to. The "fuse" has been relocated to outside the can. Some are working on that, I've done some experimenting myself. Like I said it's early.
                      A guy would have to be blind or something to think there is no difference in performance & longevity with the "optimized" motors. We know it is and will continue to happen as long as they have a dimension rule, and until they are convinced they have found the ceiling. It will be interesting to see where that is, and the combinations used to get there. Is it a bad thing? I guess that depends on if you're leading or following, shaking, or baking.
                      It's ok regardless, let's race!
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • properchopper
                        • 6958
                        #131
                        I promised myself to stay out of these discussions BUT I do race two "Ltd." classes every season so I'm affected by what's going on, Sooo...
                        I agree with you Mr. Smock ; "A guy would have to be blind or something to think there is no difference in performance & longevity with the "optimized" motors".
                        I have two "seasoned" Ltd motors (from the original list) on my bench that have been "experimentally massaged" to endure higher stator temps and not burn up before a heat is over {at least that was the original intent}. OF COURSE there's not much distance between that intention and "let's prop up now & go faster". EEk. (these are on the bench ONLY - no replicatible data as yet BUT...)
                        I have a thought* (don't be scared- I've had some previously) and of course I know with knowingness that ANY suggestion can and will be met with some good-intentioned counterpoint BUT given that the updated "size" rule could be amended to include the old "as delivered by the manufacturer" codicil it would eliminate any frankenstatoring. Make it better for noobies (one of several reasons for Ltd. classes to begin with.) OK-hard to tech - sheesh
                        *( I also think a 10 foot eight inch long rigid frame motorcycle with a foot clutch/hand shift and no front brake is good thought, so....)
                        • Doug Smock
                          • 5264
                          #132
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • properchopper
                            • 6958
                            #133
                            Don't really see too many of these at races, actually...... [1936 H-D Knucklehead]
                            Although Al Waters does show up on his Honda Gold Wing towing a tiny trailer with his boats inside
                            Not Al's but similar
                            • Steven Vaccaro
                              Administrator
                              • 8724
                              #134
                              Id agree. There are advantages with mod motors. The problem with be teching. It would be the honor system for the most part.
                              Sent from my SM-N950U using Tapatalk
                              Steven Vaccaro
                              • properchopper
                                • 6958
                                #135
                                If rule passes I'm ready (motor pic's stolen from IW posted by )
