2017 Winter Warmups
  • RandyatBBY
    • 3915
    #196
    Originally posted by madmikepags View Post
    Upon looking at the Leopards the 4082X2 motor with the 1600kv looks interesting, as we are going pretty fast with the limited 1500kv motor I would try this motor with a 450/2 or a 452/2 prop. This actually seems pretty enticing as I've been Thinking about a change for my P-Offshore setup. I have a Neu 1521/1Y that is 1577Kv I think I'm going to try that!!!!
    Well this is good for me I have the Neu 1521/1Y 1577Kv, and Steve Slusher has the Neu 1521 1.5D
    Randy
    BBY Racing
      • 9438
      #197
      Randy, if it were myself and I was lookin for a TP setup, the TP I would look at is the 3650/3Y (2060kv) that looks comperable to the Neu 1521, you could also use it in straight up P-mono too. I would try it and prop it with a M445 (a little less blade than the X445). It will prob be a little more efficient than the Neu 1521 B/C its a Y wind and not a D wind. Anyone think or know and different let him know.
      Typically 36mm motors are more efficient than 40mm motors. Many use the same diameter rotor for the 36mm as what goes into a 40mm. Yes Y winds like 1Y's are easier on esc's.
        • 9438
        #198
        Is the old Pro Boat Water Cooled RC Brushless Marine Motor PRB 3310 A3630 - 1500 KV the same as the new Dynamite DYNM3835 A3630-1500Kv 6-pole Water-Cooled Marine / Boat Brushless Motor ?
        Dunno but I'm sticking with the DYNM3835 http://www.ebay.com/itm/191717747608...%3AMEBIDX%3AIT
        $54US and Ray Presnell seems to make them sing.
        • T.S.Davis
          • 6228
          #199
          P offshore
          TP 4060 1950kv on 4s10k with an x450. Easy breezy lemon squeezy.
          Noisy person
            • 9438
            #200
            P offshore
            If you had a perfectly fine Neu 1521 1.5D and the motor you mentioned, which would you choose over the other? I have two 1521's bought used on swap shop a couple years ago and they run awesome. P mono and offshore, just change prop.
            • RandyatBBY
              • 3915
              #201
              You would think the Neu would be better wound.
              Randy
              BBY Racing
              • T.S.Davis
                • 6228
                #202
                Interchangeable in my opinion. We've do e both. They're so close that it will come down to driving.
                Noisy person
                • madmikepags
                  • Aug 2012
                  • 1359
                  #203
                  anyone here need a 1530/1Y?
                  We call ourselves the "Q"
                  • MarkF
                    dinogylipos.com
                    • Mar 2008
                    • 979
                    #204
                    Thanks for all the suggestions guys. I guess the TP 5650 motor looks good to me because it's 1/2 the price of the Neu and it's a 6 pole and a little over 100gr heavier so should have more power for more aggressive or bigger prop.
                    Can the Neu swing a 455 prop?
                    Mark
                    • madmikepags
                      • Aug 2012
                      • 1359
                      #205
                      I've swung a 457/3 pitched up on my sprintcat with no problems. Also ran a prather 250 on my Q-Sport whip with that motor. The should have no problem swinging that wheel.
                      • RandyatBBY
                        • 3915
                        #206
                        What is the kv? 1300?
                        Randy
                        BBY Racing
                        • RandyatBBY
                          • 3915
                          #207
                          Steve was real impressed with you guys, he learned a little too. He wants to come back next year. So Looks like we are going to be back again.
                          Randy
                          BBY Racing
                            • 9438
                            #208
                            1100kv
                            • RandyatBBY
                              • 3915
                              #209
                              1100kv
                              Thanks Ray
                              Randy
                              BBY Racing
                              • MarkF
                                dinogylipos.com
                                • Mar 2008
                                • 979
                                #210
                                Ray P
                                Are you going to the race in Needles? I signed up my T mono. For those of you that saw my T mono at WW the flier 12s 320 amp esc that I tried burned up after 4 laps. The second one I have, they sent me 2, is working fine. I know some of you were interested in the new flier esc and the first one that burned up I think was a fluke. We'll see how the second one holds up though.
                                Mark
