2014 NAMBA SAW event at Legg Lake, Ca. (Aug 22, 23 & 24)
  • Darin Jordan
    • 8332
    ... and... at least by my reading of the rules, P-OPC and "T-OPC" (open) can run "Any amount and/or size
    of motors
    " (That's copy and pasted directly from the rulebook)...
    So... are we going to see that TWIN P-OPC when you are here??
    Darin E. Jordan - Renton, WA
    • RaceMechaniX
      • 2825
      And it is not just twin motors allowed but any number of motors. One racer showed up with a 4 motor conquest. He did have to use only 2P maximum though under our rules.
      TG
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • Darin Jordan
        • 8332
        TG
        Actually, the rules don't say that... We don't have paralleling limits any longer.
        What they say is that you are allowed a maximum amount of mAh... 10,000 for P and Q, I think 12,000 for S and T... You have to distribute that across the motors how ever you please.
        For example, with two motors in P, you can either power both together by a single ESC and 10,000 mah@14.8V, or by 2 ESCs with 5000 mAh each @14.8V.
        I need to go back and read, but there might be something in there about how one can divide up Voltage across the motors as well, but I don't recall exactly.
        Bottom line would be that you can't have more than the maximum amount of allowable mAh on board when running the maximum class voltage.
        • thomaslambo
          • Nov 2010
          • 232
          Exactly, so use it as efficiently as you can
          • MarkF
            dinogylipos.com
            • Mar 2008
            • 979
            #35
            The guy with the 4 engine cat had 4 - 6s 2500 packs. One for each motor. Having such small packs really hurt any chance of getting any records. I ended up beating him with my mono.
            Mark
            • rearwheelin
              • 1941
              #36
              Mark
              it was actually worse than that , I had 4s series into 2s x2 . They were 5000mah Turnigy 40c , instead of making a battery splitter I just took the esc's and paralleled them by soldering there battery wires together . If I only had the new thunder power batts I would have had a chance
              --Albert Einstein
              • MarkF
                dinogylipos.com
                • Mar 2008
                • 979
                #37
                I new somehow you only had 2500 mah going to each motor. I would have liked to see that boat run on 4 5000 packs. 1 to each motor.
                Mark
                • rearwheelin
                  • 1941
                  #38
                  I tried. I ruined 3 of my packs that day.
                  --Albert Einstein
                  • Ub Hauled
                    • Aug 2007
                    • 3031
                    #39
                    impressive speeds gents, congrats to all participants.
                    • RandyatBBY
                      • 3915
                      #40
                      Mark
                      Man it was great sounding though, Very impressive to watch.
                      Randy
                      BBY Racing
