2014 NAMBA Fe Nationals
    • 7512
    I'm in....got permission from the wife already!
    • jaike5
      • 564
      I'm in , bringing the wife ! that solves that issue. Race on....
      Cheers , Jay.
      • rightturnonly
        • Jan 2009
        • 143
        Fred,
        We enjoyed everything at the MI Cup this year. I've already got clearance from headquarters to make the trip North.
        John
        JOHN A. GROSS
        MILLBROOK, AL
        Crickety Crack Racing Team
          • 7512
          Hey Fred...no Open Cat???
          • fas
            There just toy boats
            • 526
            John
            with this being a nationals we have to list the class as namba class with that being said
            T-offshore specs boat must be 60" or under any electric power can go from 6-10s 12000 mah limit 4 minute run time
            T-Cat same as above just a 6 lap sprint
            these are what we called open cat and open offshore at the Michigan cup last year
            When all else fails floor it
              • 7512
              Duhhh..makes sense..thanks Fred.
              • Darin Jordan
                • 9446
                Guys... just for reference... Catamaran is now an official class in NAMBA.
                8. CATAMARAN
                a) General Rules
                i) Catamaran rules are intended as a supplement to the General Racing
                rules of NAMBA. In the case of conflict, the Electric Catamaran
                rules will prevail.
                b) Hull Specifications
                i) Catamarans shall be a stand-off scale version of an Offshore
                Catamaran style of hull, with two sponsons that normally run the full
                length of the hull.
                ii) Sponsons are separated and connected together by a tunnel.
                iii) Sponsons may have lateral breaks.
                iv) Inboard or outboard mounting of the motor(s) is permissible
                v) Hull length must conform to those listed in Rule D.2.a in this section
                for each Power Specification
                Part v) indicates that the class is open to ALL power specifications per D.2.a.
                Therefore, N1, N2, P, P-Ltd, Q, and T, are all eligible for a Cat class at a National event.
                T=Open, for those of you still waiting for your coffee to brew... :)
                Darin E. Jordan - Renton, WA
                • RaceMechaniX
                  • 3024
                  Darin,
                  I believe T is still just Q and T or did that change?
                  TG
                  Tyler Garrard
                  NAMBA 639/IMPBA 20525
                  T-Hydro @ 142.94mph former WR
                  • Darin Jordan
                    • 9446
                    Darin,
                    TG
                    Tyler... Ignore the bottom part... Here is a snapshot of the Power Specifications table...
                    The bottom was just tinkering for the other thread...
                    The way I read it... Q is it's own class, and T is it's own class, but T can be run with anything from Q to T... :Blink:
                    • fas
                      • 526
                      Yes Darin is right
                      Q is only 6s with a 10,000 mah limit
                      T is 6s to 10s with a 12,000 mah limit
                      so if you have a q-offshore you can run it in t-offshore also, that is what I did at the Michigan cup last year just put in 2-6s 6000 instead of 2-6s 5000
                      and I won the class running with Pags,haines,tucker,droby it was not easy but I just stayed on the pins so it can be done
                      • 427srule
                        Racer
                        • 188
                        Hey Guys,
                        I was going through the list of classes I would like to run and noticed SV27 is on the list.
                        Any special rules?
                        At the 2011 Nats, we ran stock and modified(prop only)
                        Thanks,
                        Mike
                        • fas
                          • 526
                          Mike the way sv-27 will be ran here is bone stock, tabs and turn fins are the only thing you can mess with and the prop will be a 42/55 S/B only
                          Fred
                          • 427srule
                            Racer
                            • 188
                            Fred
                            Fred,
                            Thanks for the info
                            Mike
                            • Steven Vaccaro
                              Administrator
                              • 8932
                              This one may get me from behind the desk and headed west.
                              Steven Vaccaro
                              • T.S.Davis
                                • 6266
                                It better. I don't want to have to drive over to pick up your boys. We'll leave you home if we have to mister.
                                Noisy person
