Miss Attitude 88 mph run
    • 7990
    For the typical SAW pass at official events, most racers will stop at the far end of the lake and wait for the wake to settle down. Then we make one pass down the middle of the course, and if we can we follow that path back in the opposite direction (need back-to-back passes for records). Running in your own path means pretty flat water with no angled waves - as long as the next pass is pretty soon after the first pass.
    • properchopper
      rcgoatbuild@snotmail.com
      • 6958
      Jay, You stood next to me on the stand when I set my 2006 LSO record and instructed me to do just that; I was so green that I never asked you why I should wait { I thought it was to let the NIMH's breath some } Now I know [ BTW when does this green go away ? ]
      • Ub Hauled
        • Aug 2007
        • 3031
        ...BTW when does this green go away ? ]
        once you have a record...
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          So true, Donald Campbell did not do that and that is one of the apparent reasons that Bluebird K7 flipped and he was killed.
          Douggie
          • properchopper
            • 6958
            I hold four records but still need all the help I can get
            • Ub Hauled
              • Aug 2007
              • 3031
              but you are not a "green horn" anymore...
              • properchopper
                • 6958
                That's debatable !!
                • teach
                  • 509
                  That's not a green horn...it's an old fart horn.
                  Sorry couldn't help it!!
                  • Gary
                    • Jan 2009
                    • 1104
                    Ok Just came back from lake and made two runs like you said Fluid, come back through my own path. I looked over the lake and decided a new aproach . Boat ran a 98.2 mph and comeing back 97.0 mph but fliped at the end{hit some wake} I tryed runing it out as far as possible. Almost at 100.....
                    H&M 1/8 Miss Bud 73 mph
                    Chris Craft 16 mph
                    • Jeff Wohlt
                      • 2716
                      You might consider coming off the throttle gently at the end of the run. I think the stopped prop becomes an issue when getting out of it too quickly. Jay would have more on that.
                      www.rcraceboat.com
                      jwohlt5362@yahoo.com
                      • detox
                        • 2310
                        What prop are you using?
                        • Gary
                          • Jan 2009
                          • 1104
                          M645 modded by me. Ive done at least 6-8 of these props and keep making small changes and keep going faster. Your wright Jeff i need to get in the habit of come off the throttle real slow to avoid flips.
                          Chris Craft 16 mph
                          • Gary
                            • Jan 2009
                            • 1104
                            I finally broke 100.Boat went 102 mph this morning, with a crash! Hydra decided to go up in smoke on shore and took out a battery aswell.Video sucks because i set it up on a trypod do to the fact i was by myself a 5:45 am so im not even going to post it. Here is some carnage. http://www.youtube.com/watch?v=-6eJo7a4O2E Ok here is the video. I had to set camera up on tripod so there is a long delay between turning on the camera and getting boat moving so fast forward to the halfway point. Again not to good. I had to spilt it up between geting the boat and recording again. Remember fast forward !!!http://www.youtube.com/watch?v=FDWFJSyFuAU
                            Chris Craft 16 mph
                            • teach
                              • 509
                              Congrats!!
                              • tth
                                • Apr 2008
                                • 1510
                                Good work....Just like anything else, when you push equipment to the limits its just a matter of time. I would like to see the run.
