My TFL 41" Zonda coming up to speed
  • ArnoudRC
    • Oct 2020
    • 50
    Just curious on the setup. Still running the two piece flexshafts? What was the prop size? ABC?s? Thanks
    Verzonden vanaf mijn iPhone met Tapatalk
    • MADRCER
      • Feb 2017
      • 765
      My flex shafts and abc props are both custom by Chris Hoffmann (dasboata on here) No specs are given on the props due to a few that wanted to disrespect us after my Zonda hit speeds that had never been achieved before in a RTR/ARTR boat. I ran the stock flex shafts to 106 or 109mph They did fine except for on one run a bullet nut set screw came loose and after that I swapped them out for the dasboata shafts. You can run abc props on the stock shafts and I know guys say you can't, but you can if you change out the large TFL drive dogs for the small octura dogs. By doing that it will allow more room for the longer hubs of the abc props.
      • ArnoudRC
        • Oct 2020
        • 50
        Thank you for reacting! Appreciated. Will soon receive a Hydromarine Freya Cat. Will run it single motor.
        • MADRCER
          • Feb 2017
          • 765
          Here is my latest run making the TFL Zonda "The Worlds fastest RTR Boat" (running factory stock electronics). The boat hit 113mph by the gps devices and the props used were from Chris Hoffmann (dasboata). More to come!
          • MADRCER
            • Feb 2017
            • 765
            First outing of 2021
            • dasboata
              • Dec 2010
              • 3972
              nice pass Mark
              • MADRCER
                • Feb 2017
                • 765
                nice pass Mark
                Thanks Chris! Now its time to go to the big area to run....I've maxed this lake out and not enough room. The boat keeps pulling mph but I have to let off early. Should get a couple more mph fairly easily. Only need time now...
                  Good work, takes some time and fine tuning but man you have it dialed!! Congratulations
                  • MADRCER
                    • Feb 2017
                    • 765
                    Thanks!
                    • MADRCER
                      • Feb 2017
                      • 765
                      Worlds Fastest Zonda @ 120+mph (on stock electronics)
                      The Worlds fastest TFL 41" Zonda (on stock electronics) hits 120mph+!! One gps got the boat at 120.7mph and 123.6mph on
                      the other. The osd datalogger got the boat at 119mph. As I let off the throttle the rudder snagged a limb and broke the rudder breakaway causing it to roll. I was able to dry the other
                      gps out and have a short video of that at the end. Huge thanks to Chris Hoffmann (dasboata) for the Awesome set of props!. More to come!
                      • vvviivvv
                        • 1148
                        Massive congrats, I'd love to know the base prop that you started with, I know all the prop mods etc are top secret but what raw prop did you start with?
                        Uk SAW record holder
                        • MADRCER
                          • Feb 2017
                          • 765
                          Thanks Appreciate that! Out of respect for Chris and his business he and I discussed that the specs won't be released on these props.
                          • vvviivvv
                            • 1148
                            But the props are available to buy or whats the deal?
                            • MADRCER
                              • Feb 2017
                              • 765
                              Chris sells every single prop that I run and test for him. I just honor our mutual agreement and keep the specs just between us. I suggest you hit Chris up for details on ordering and pricing.
                              • MADRCER
                                • Feb 2017
                                • 765
                                Here's a YouTube shorts video of a 118mph pass cut down. More to come!
