10 cells and a Castle Creations motor
  • tryinotocrash
    • May 2012
    • 203
    http://www.offshoreelectrics.com/pro...eations+Motors
    Here are a couple of quick videos of the boat I have been working on . I have pictures on the show off your boat forum.
    Mark
    Don't forget to put your brain in gear before you engage your mouth! Thanks Dad!
  • dasboata
    • Dec 2010
    • 3972
    10 cells really ? ESC are you using
    • dasboata
      • Dec 2010
      • 3972
      10 cells really ? ESC are you using? I don't want to burst your bubble but that boat should be 25-30 MPH faster sound like you have some serious drag problems ?
        Nice rebuild! That motor runs great on 10 cells, several club members run them in their T-Class race monos, usually in the 70s. It seems a bit slow and the rpm seems high - what prop are you running?
        • tryinotocrash
          • May 2012
          • 203
          This was the second time it was in the water . I have not had time to fix it till now. I have not run it yet with the new ESC . No buble to burst here . I will sort it out soon .
          The new ESC is a 300 amp Fighter cat . As for the prop I have not tried another yet but I will . It seems a bit small but it was on it when I got it .
          I am open to suggestions on the prop .
          I have some pictures in the picture section of show off your boat. I am still learning .
          The second ESC went up in smoke . Then it sat for two years .
          • tryinotocrash
            • May 2012
            • 203
            The prop measures 1.705 so 43MM it seems not sure the pitch .
            I am learning so I posted this and am open to opinions and suggestions or ridecule I don't care I am all ears..
              No one is born knowing everything about FE boats. The prop you are using explains the poor speed and high rpm....it is WAY too small for the boat and power setup. That motor and ESC will handle an x457, x462 and larger with no problem - depending on your packs of course. The tiny prop may also explain why the ESC fried - over-revving a BL motor is hard on the ESC.
              • tryinotocrash
                • May 2012
                • 203
                Awesome. That's what these boards are about. I tried to find people here in Chandler to learn from. A lot of gas boats and some electric. I will get another prop or two today.
                And yes the boat had a lot of drag on it due to a bull that was crap. I put a straightest on the bottom and that's when I tore it all apart and rebuilt it. I appreciate the help. I will get new video as soon as I can.
                • oscarel
                  • Dec 2009
                  • 2373
                  I have one in a 41in cat and it's at the 70mph mark. I'm using a cut down 6516/3.
                  • tryinotocrash
                    • May 2012
                    • 203
                    So you cut the diameter down? To what if I might ask?
                    • tryinotocrash
                      • May 2012
                      • 203
                      I'm sorry I misread the calipers the prop that was in the video was an X445. Still small but not as bad. I found a bigger one from an old nitro boat I used to have it is a 48.5 ish dia. It says PRB80155. Maybe that will work for now if I cup it some?? I will have to look that up to see what it is. Thanks for the help guys.
                      Mark
                        That prop is a PRB0155. Diameter is 1.9"/48 mm, pitch is 3". This is still very small in diameter for that motor.
                        • oscarel
                          • Dec 2009
                          • 2373
                          Its cut down to 3.5" overall pitch. The one I have was done by Prop Works West, but he's not doing props anymore. Chris (Dasboata) would be a good source for one. A mono is gonna take a different prop though, again get with Chris and I'm sure he can get you close.
                          • dasboata
                            • Dec 2010
                            • 3972
                            thanks Oscar !!!
                            • tryinotocrash
                              • May 2012
                              • 203
                              So the confusion continues . I have a .250 drive shaft and there seems to be a lot of .187 props for electric but huge props for .250 shaft. Unless I go to a gas boat prop selection which I have no problem with but I can't seem to just figure out a diameter to start with. I kind of get the whole pitch part but I can't tell what dia. some of the props listed are to get a good starting point. 55MM? 60MM? 65MM? 70MM? where to start?
                              Mark
