Shocker 2nd Rebuild - Video
  • dmitry100
    • Mar 2015
    • 1264
    Hi,
    So I finally rebuilt my Shocker with new OSE 3/16 drives, stuffing tubes, OSE .187 flex (was .15 originally), MBP collets, OSE STS 187 (Shaft Tube Seal/Flex Saver), new pair of 2050kv TP 4050's, and fiberglass inlay. All this took me almost 2 weeks to do. I was surprised by how time consuming everything was especially mounting the drives with the stabilizer mounts which weren't exactly a 100% fit for this hull, but it works.
    Here is my 3rd run with a bit of adjustment to trim with 445 CNC props (started with 442's). Temp's were barely warm to touch on 442s so I moved onto 445s.
    My cheap $50 gps clocked this run here at 70mph... but I think if I ran on the bigger part of the lake I'd probably get some better speed readings since it's not one of those $150 high sensitivity garmin gps's.
    This last run motor and ESC temps were fine. Except the revo lipos which were around 95*F+ when I checked... some of them were slightly puffy. :-/
    They are back to normal now. Voltage readings on the cells were always perfect matching with all 4 3s packs (4.275v etc) but now when I recharged them afterwards they all show 1: 4.223V 2: 4.265 3: 4.247
    Not sure why the packs were that hot but I think it might of been due to placing them between foam which I was hoping would be a good idea for extra floatation just in case and to keep them in place.
    So I'm currently cycling the lipos on the Cellpro powerlab so hopefully these packs aren't ruined.
    Some pics of under the hood:
    My only complaint so far is my Flysky GT3C radio... response starts lagging by 1 seconds when its at a distance which is why the boat flipped in the video. So I guess I'll be shopping for a new radio so if you guys have any suggestions let me know :)
    Anyway... thoughts? suggestions? Except the lipo thing I'm happy with the boat so far.
  • lt130th
    • Apr 2014
    • 858
    Really makes me want to get started on mine. I've had a carbon Shocker SAW hull for about a year, & have everything for it, but I've been building other boats. Could only be me, but that looks like more than 70mph. You might be right -need more space to sustain speed for your GPS to log it? I'll be using my TP 4060's to turn a set of 45mm 3-blades that dasboata worked up for me. Shooting for triple digits. I would think your setup would get you pretty close, too.
    • dmitry100
      • Mar 2015
      • 1264
      I was actually thinking to throw some boca bearings I bought into those OSE drives I have there. Not sure how much of a performance increase I'd get versus the time trying to machine them to make them fit though.
      But yea, that... or I should prob get a new GPS :) theres some newer model garmin's on ebay for around $60 bucks.
      Is that the version of the shocker that Fightercat used to sell? I wish they still had them in stock... I would have gotten one from there.
        Looks good Dmitry, more room is certainly needed. It certainly has more than 70 in it but doubt you'll get it there. But it looks good and stable. Everything came back with good temps?
        • flraptor07
          • Aug 2013
          • 2451
          Man that thing screams! If you ever got it in a bigger lake where you could run it out, it would probably run around mid 80s. Temp wise on the batteries 95deg. is not to bad but I don't know what to tell you on the puffing, except if the outter wrapping is sealed real good sometimes the trapped air will expand and it will appear that the battery has puffed when it really hasn't.
          • dmitry100
            • Mar 2015
            • 1264
            Yep! Today's passes clocked 80 mph on that GPS and I ran it in the same place except I ran it a tad bit farther across the lake this time.
            I probably wouldn't be able to control it any farther than this though... the radio lag really makes it harder to control the throttle and turns at a distance.
            Would a better radio fix this, or is this something most radios experience on water?
            srislash: Temps were always looking great, barely warm on every half dozen passes... even the lipo temps are fine except only after I check after lipo cut off (which is set at the highest of 3.3V in the SF esc) I noticed the lipo temps were around 98 to 109* F... the part of the lipos were a lot cooler-- about 85-90* F. I just hope I'm not killing these lipos... I think I definitely need to give the lipos more room to breath. I even removed most of the foam around them this time around and it didn't seem to make much diff. After cut off -- cell voltages would show 3.40 to 3.45V on one set of packs and 3.33 to 3.38 V per cell on the other set of packs. I'm assuming that slight variation in voltage between sides is normal.
            flraptor07: So its normal for them to expand a bit after running? (they do go back to normal when cooling down after around 15 mins)
            • dmitry100
              • Mar 2015
              • 1264
              After some research 40-45* C temps are pretty normal after a run... and it seems that Revo packs are capable of taking alot more heat.
              So I'm thinking now to go and give it a shot with the next step: 448 CNC prop.
              I'll let you guys know how it goes :)
              • flraptor07
                • Aug 2013
                • 2451
                flraptor07: So its normal for them to expand a bit after running? (they do go back to normal when cooling down after around 15 mins)[/QUOTE]
                No the pack shouldn't puff, sometimes it's the wrap is sealed real tight and the trapped air expands in the wrapping and makes it look like they puffed. You can feel it if you squeeze the pack and it feels like a air cushion then it's just the expanded air. A pack that has puffed will feel harder and usually doesn't go back to normal.
                • flraptor07
                  • Aug 2013
                  • 2451
                  CF boats will sometimes have radio issues, you need to be sure there is enough antenna sticking up through the antenna tube.
                  • Luck as a Constant
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    Nice job Dmitry!
                    Next time you can just build your own boat instead of paying extra for all that crap you had to rip out lol
                    Boat rips dude
                    • dmitry100
                      • Mar 2015
                      • 1264
                      Luck: Thanks. Well I made a paypal claim for that thing man... but they want me to send it back to get covered by buyer protection. So I'm gonna try to get him to send me a partial refund.
                      Or perhaps if someone has a CF Shocker or Daytona hull they want to sell to me then I could prob just send it back to the seller and do an extra nice rebuild without the extra holes or things like that this time lol.
                      flraptor07: The antenna sticking out is as long as the plastic tube (if you check pics). So I tried to make it as long as possible... but the receiver antenna is kind of short though. It is pretty long right now. So maybe I should invest into some better radio. I could already imagine a crash from all that lag in the radio.
                        Temps are fine but the lipos are puffing because you are running them too low. 3.3 or 3.4volts is too low. 3.75 or higher is ideal. 3.6 acceptable. Your lipos will live a long time if you follow this. It took me a while to learn this and since I have adopted this my lipos are still good. Just words of advice Dmitry. You'll get used to a certain runtime after awhile but to learn it you could use a timer to warn you of the time.
                        Sometimes like Chris stated lipos go back to regular size. Have yours?
                        • dmitry100
                          • Mar 2015
                          • 1264
                          Yea, felt like air both times and they go back to normal shortly after.
                          I just wish I was able to set the cut off voltage higher in the SF ESC. Kind of weird that 3.3v cut off is the highest we are able to set them to in their programming.
                          I'll definitely keep that in mind. So I take it that draining them to 3.35v to 3.40v is the reason why they would even get that warm in the first place?
                            Yes this also contributes to the heat. There is a nice 'happy' spot where you have drained the capacity down but not the voltage. And at that spot you should have used 75-80% of capacity. The battery starts to work to give any more up and then more heat occurs.
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              Shawn is correct. Most of the heat generated is at the end of the run when the voltage starts to drop. When that happens things heat up real fast, so ideally you try not to get to that point.
