my 47" mono running super High Voltage 20s!!
  • Mel279
    • Dec 2008
    • 873
    The custom's wind motor for my 20s setup
    Looking good.
    20s and 370kv motor,
    How where your temps after that run ?
    • Alexgar
      • Aug 2009
      • 3701
      Impressive
      • Mel279
        • Dec 2008
        • 873
        Lenny
        the esc was surprisingly barely warm but the motor is pretty warm as Im not sure whether it is a Y or D wind since the manufacturer didnt specify it. But Im quite satisfy with the performance so far with more than 3mins runtime.
        • Fella1340
          • May 2013
          • 1025
          That's incredible, I didn't know there was an esc out there that would handle 20s! I love the idea of high voltage
          Setups. What esc are you punishing on 20s? Jeff
            Look at the YouTube where it said show more.
            Published on Aug 17, 2013
            My setup:
            Motor : TP5850 370kv
            Esc: Flier 4s-22s 400A
            Lipo: 20s ( 4 x Gens Ace 5s 45c 5800mah)
            Prop: custom prop 455/3
            Speed: not taken
            • Basstronics
              • 2384
              TP seems to carry more D than Y. One can assume.
              However I would ask. Im sure they can give you an answer.
              • Mel279
                • Dec 2008
                • 873
                Lenny
                thanks for helping me out
                Basstronics
                I have run it again y'day and set the timing from 5 deg to 20deg and it doesn't go well as it stop when I pull the throttle to the max. Now Im definitely sure its a D wind and I manage to check the speed which is about 65mph. It beat my previous setup with 10s and tp5850 820kv with similar prop at 59mph. Big temperature different also on the esc, much more cooler on 20s than 10s.
                  • 9481
                  Wow, very cool!
                  where can one buy that esc?
                  • rscheffer
                    • Aug 2011
                    • 74
                    • gerjanmonohull74
                      • Aug 2014
                      • 2
                      Sweet run on that nice mono, i like greetings from the Netherlands
