DF-33 Leopard 4082/1500kv on 6s
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 439
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
  • Rumdog
    • 6667
    Nice!
    • DK535
      • Jan 2012
      • 693
      Nice I have the same setup in my cyberstorm and it doesn't run that good
      • scoota
        FE DOWN UNDER
        • Dec 2008
        • 439
        Cheers guys , im running COG at 11 & half inch's & running 60-130c 4500mah 6s pack in front of the motor , the prop is a S&B x646 with speeds around the 55 -60 mph mark , the speedie is a seaking 180 with extra caps ....
        • DK535
          • Jan 2012
          • 693
          That's a big prop. What are the temps?
          • scoota
            FE DOWN UNDER
            • Dec 2008
            • 439
            After a 3-4 minute run every thing comes back cool , that motor makes 4.5 Hp & can turn bigger props than that with out getting hot ! But i found that set up loves the x646 after testing 5 different props ....
            • scoota
              FE DOWN UNDER
              • Dec 2008
              • 439
              At 4.6 HP/3449watts , that motor is drawing 160 amps , temps on the ESC , motor & battery never got over 36cDF33 6s 4082 1500kv (1).jpg
              Temp 3 is the battery
              All i can say guys is try a 60c plus lipo , cause this boat never performed as it did in the video , till i tried the 65-130c lipo well worth the bit of extra cash i spent on some decent cells !!!! These are the cells im using http://www.hyperionaustralia.com.au/?stg=1387&view=1387 & i found my seaking 180amp ESC didnt cut out early like they have a habbit of doing cause these cells hold their voltage & for the first time i can set the LVC @ 3.2volts
