DF Cyber Storm Mono breaking 60MPH on 6s
  • Drax21
    • Jul 2011
    • 1077
    Using a TP Power 4092 1600KV with a SK180 and 2xFlightpower 6s 3300mah 50-100c in parallel.
    I was very happy with this run.
    That is running very nice,
    Just look out for that rock on the right.
    How were your temps after that run,
    And water temp in the lake there ?
      So which prop got you there?
      • Drax21
        • Jul 2011
        • 1077
        Motor and batteries were warm, 42c, esc was a bit warmer but I could still touch it. One prop up and it would be too hot. Water was about 10c, warmer than usual.
        • Drax21
          • Jul 2011
          • 1077
          I am running an M445.
            That is great temps on the setup then,
            But that water temp sure would wake you up.
            Also what timing are you using with that motor ?
            • Drax21
              • Jul 2011
              • 1077
              Yeah I'm very happy with it all round. It is very cold up the lake most of the time, situated on top of hills
              Timing is set at Setting 2 - 3.75 degrees
              • SSchevy
                • Aug 2011
                • 9
                good running .
                What prop is best df 33 hull and scorpion hk 3026/2300 kv outrunner motor , hifein 200 A 3-6s esc ?
                I'm thinking to try these? x446 / 3, X448 / 3, X450 / 3 and X452 / 3?
                • Drax21
                  • Jul 2011
                  • 1077
                  Originally posted by SSchevy View Post
                  good running .
                  Thanks , I'm not sure with outrunners as I have never owned one but based on motor can size I would start with a X442 2 blade on 4s and work upwards. If X442 runs cold or cool enough then try the M445. If it runs very warm that will be enough.
                  • RIPFENCE
                    • Sep 2009
                    • 1577
                    This makes me miss my cyberstorm real bad..i love this hull..good running boat
                    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
                    • Drax21
                      • Jul 2011
                      • 1077
                      Yeah I recently sold all my other boats and kept this one because its my favourite.
