Jae .21
  • jujux1
    • Nov 2011
    • 30
    I use flex shaft .187 with strut from hydro&marine
    • martin
      • 2869
      What settings did you use on the Seaking 180, did you set to auto calculate on the cells or manually & what lvc & timing. As i know some have had problems with lvc cutting in to half throttle when using auto calculate on cells.
      • jujux1
        • Nov 2011
        • 30
        I always switch off the lvc on seaking esc which are too sensitive.
        But i leave auto calculate on the cells.
        I tried different timing until 22.5°, the motor is still cold
        • martin
          • 2869
          Do you just time your runs so as the voltage dosnt drop to low.
          • jujux1
            • Nov 2011
            • 30
            Hi !!
            New test today with same set up : 87.6 mph !!!
            • jujux1
              • Nov 2011
              • 30
              Hi !
              new record for me 150km/h 93.2 mph with same set up , I ve spend some time on H7 ....
              • martin
                • 2869
                Great speed, what work have you done over a stock H7. Thanks.
                • jujux1
                  • Nov 2011
                  • 30
                  I have only reduce the thikness, also change the rudder for stainless 1.5 mm
                  • martin
                    • 2869
                    Do you use the JAE turn fin on the sponson or perhaps a smaller fin or no fin for SAW runs.
                    • jujux1
                      • Nov 2011
                      • 30
                      Exactly, no turn fine for saw runs, the difference is 7-8km/h
                      • martin
                        • 2869
                        Thanks for that, also do you use the bec on the esc or a separate power supply for the rx & servo & do you fit the esc in front of the battery with quite long wires to the motor.
                        • jujux1
                          • Nov 2011
                          • 30
                          no I don't use the bec of the esc, I use a ubec and exact, the esc is in front of the battery with long wires to esc
                          Here is a link of mine on frenc forum
                          • martin
                            • 2869
                            I notice you have been having problems with the boat pulling to the right, one of the mods that helps with this problem is to use toe in on the front of the right sponson around 2-3mm. This is a pretty standard mod on the JAE boats if they pull to the right & wont run straight.
