Mark will fill in the details but here is the video..............
Mark F pilots a mini hydro with watercooled brushelss motor
Mark hit a bouy!??? No way that was Mark...:) Fast little bullet.
2S...3S and what...about a 3900 kv motor?
Yea the first thing out of Joe's mouth was you couldn't hit that buoy if you tryed. I was trying the new water cooled motor from AEO. The motor looks really nice and well built. I will get some pictures up when I can. The motor has a 3mm shaft instead of the normal 3.17 mm shaft, so the coupler I have doesn't fit right and I am getting a bad vibration. Anybody know where I can get a 3mm motor to 4 mm shaft coupler?
MarkLast edited by MarkF; 12-10-2010, 12:04 PM.
Hi Mark. Jim here. I'll measure our couplers and shafts for you tomorrow.Mini Cat Racing USA
www.minicatracingusa.com
Here is a link to the motor. The shaft size is 3mm. This motor looks very good by the way and I believe is going to run great once I get the coupler I need.
Mark
Just 1 will be fine. The cable is one of those 4mm square drives that come with the boat. Its only square at the prop end though and round at the coupler end. Some set screws at both ends will work fine. I would like one as soon as possible Jeff.
Thanks
Mark
I will try and get it out Monday for you. Is 3/8" stock okay for OD size?
Ha, I am testing the new AEO 400 water cooled outrunner, and ran into the same problem. There aren't many 3mm couplers out there. I need a 3mm-.098. Some guy over at RCgroups said he would make me one. I see ETTI has one, but it might cost me $20 by the time I ship it here.
I use a similar motor in my mini rio.http://www.hobbypartz.com/88e-ads-30...ool-motor.html The 1/8 in. couplers OSE sells fit great.I run the 1/8th to .98 cable.Hope this helps.
