My Kintec Prince.
  • Rottenbelly
    Captian Big Nerd !!
    • 89
    My Kintec Prince.
    Updated last post with a bigger prop run!!
    This is my first FE boat besides my Blast rescue boat.
    I talked the wife into running the camera for me.
    You will here my daughter referring to the Poo-Poo Express,.... that is the name we gave my rescue boat for when happens!!
    Boat ran great. Seemed really stable over the boat wakes.
    I did break loose the battery mounting plate from the hull.
    What should i use to remount it?? Epoxy or???
    What would y'all think the speed was on it? I am going to try to GPS it one day.
    Bigger prop run.
    My work boat has 12,000 HP!!!
  • Jesse J
    scale FE enthusiast
    • 7241
    Sweet, nice run and great place - is that the river?
    how were temps after that run? I would say speeds were in mid 30s. If temps were ok, you may prop up to next size if you want. I love those rollers you were jumpin - I love choppy water.
    You should be good with epoxy on the battery tray, make sure its real clean first and bone dry. Looks like you need some boatin cronies.
    "Look good doin' it"
    See the fleet
    • Rottenbelly
      Captian Big Nerd !!
      • 89
      That is one of the 2 big lakes by my house.
      The esc, motor and battery were all just barely even warm. Nothing even felt close to hot.!!
      Looks like I may prop up a hair when I get back. The water may not freeze all winter down here!!
      Going to go grab some epoxy and fix up my tray. Also going to reinforce around motor with some carbon fiber when I get home from next trip.
      • WrknItUp
        • Jun 2010
        • 338
        Sounded like you caught the beach a little on that final pass! Oops? Ive done it a few times to. I accidently jumped the bank one afternoon with an abs hull. What a sound to hear!
        I believe it's my god-given right, To destroy everything in my sight. Cause it never gets dull, it never gets old. The only thing it gets is more bold. Drinkin', fightin', going to the game. In our world it's a way to stay sane. If you're asking me. To have it my way, I'd say that's One fine day. ---- The Offspring
        • Rottenbelly
          Captian Big Nerd !!
          • 89
          If i did it was close!!
          I didnt break my breakaway bolt.
          I almost hit that orange bouy at the beginning though!!! what a save!!
          I also hit a log last week and tested the breakaway bolt...worked like a charm,
          • ALD
            • May 2010
            • 96
            Nice vid. I have a kintec prince also and run 4s 2pack 5000mah 40c with a 1800kv motor and it runs 40mph plus- no gps. I use a balanced/sharp gimracer 42 x 55 2 blade prop. I changed all conectors to 5.5 bullets because things heat up pretty good and I run for 5 min. only. You should try the prop- boat is a bullet and will turn at full speed in calm water.
            • Krowbar69
              • 237
              Cool boat and lake.. wish i had something like that by my house.. im stuck with saltwater...
              • Rottenbelly
                Captian Big Nerd !!
                • 89
                Thanks for the tip!! That was the prop i was thinking of getting.
                I also have a bunch of 5.5 connectors, ready for a soldiering party.
                • Rottenbelly
                  Captian Big Nerd !!
                  • 89
                  Took the suggestions and got a 42x55 2 blade. Running on 4s with stock suppo esc it got warm but not hot. Went thru a 4000 mah battery real quick though.
                  It is the 2nd video in the first post.
                  • Jesse J
                    scale FE enthusiast
                    • 7241
                    looks good man, must mean you are back home and gettin the vegas ready.
                    was that poo poo pond?
                    See the fleet
                    • Rottenbelly
                      Captian Big Nerd !!
                      • 89
                      The pictures of the jeep look great! Glad you are having fun with it!
                      LOL!! Yep, Had the vegas in the truck this morning but had 15-20 mph winds all day. So came back home and my new prop was in the mail so i sharpened it up and took the prince out for a spin. Ended up leaving the vegas at home and by the time we got back to lake it was smoothing out.
                      That is a different lake. I ran my blast in a pond that the cows had been using , so the hot cow crap water running thru the cooling system has permanatly tainted it!!!
                      Its my rescue boat now and we call it the poo-poo express for when happens.
                      • tunnelvision
                        • May 2010
                        • 685
                        Looks good!! These are really great boats! Loads of fun to drive. Just gps'd mine with a 3s 5000mah 30c, stock motor, stock prop and 120amp seaking at 34.8mph. I hear 4s will fry the motor?? Any heat problems? I am waiting on a Leopard 2860 2700kv for my 3s/4s setup!
                        Go Fast...Turn Right...
                        • Rottenbelly
                          Captian Big Nerd !!
                          • 89
                          Mine has never really got warm till today with the bigger prop. It was only slightly warm today, need to get a temp gun. But it just felt like some pocket handwarmers. My esc felt hotter than the motor.
                          Mine has the SV 27 1800kv motor.
                          • tunnelvision
                            • May 2010
                            • 685
                            4s on that setup will be cool I would think. Did you have to change the motor mount? What flex do you have in there, 4mm or .150?
                            My temps usually around 85 esc, 125-130 motor, and battery 112-115 after a 5 minute all out run.
                            • Rottenbelly
                              Captian Big Nerd !!
                              • 89
                              I have the .150 with 3/16th drive.
                              Mine came with the bigger motor mount. I did get some carbon fiber to reinforce the hull/ motor mount area.... just in case.
