Dragon Saga 34 inch cat 9xl's/14.8v/40mm 61.5 MPH
  • JPriami
    N4FOX
    • 1675
    Video's from Sunday 9-12-10 of the Saga 34 inch catamaran ive been working on lately. Running dual Feigao 9Xl's on 4S packs with CF 40mm counter rotation props. Hit 61.5 MPH with the added weight of the GPS in the boat.
    There are 2 videos of the same run. One camera was mounted on my glasses and the other was taken from a camera phone and shows the GPS reading as I take it out of the boat.
    eye glasses clip in 1080 frame
    camera phone
    eye glasses cam
  • Brushless01
    • Apr 2010
    • 487
    Wow what size motors are they ??
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
    • JPriami
      N4FOX
      • 1675
      380's
        • 9438
        Yeah baby!!!
        • martin
          • 2869
          Is that stock motors or did you upgrade them, If so what motors exactally did you use and what kv are the motors. Is that also the stock pair of 70 amp esc or did you change them as well. Nice runs by the way. Martin.
          • JPriami
            N4FOX
            • 1675
            In that video the motors are upgraded dual Feigao 380 9Xl's. 2612Kv
            Its the stock 70 amp esc's on 4S
            With the stock motors at 2881Kv and 36mm props I hit 55.8Mph
            • martin
              • 2869
              Did you run the origanal motors on 4s or did you use 3s. Martin.
              • martin
                • 2869
                Did the boat come with counter rotating motors and props as the pictures ive seen on some of the varies sites show the same props on both sides
                • Steven Vaccaro
                  Administrator
                  • 8724
                  Wow, I didnt realize those 380's could do that! Good work.
                  Steven Vaccaro
                  • JPriami
                    N4FOX
                    • 1675
                    Yes it came with counter rotational props and cables. The motors are reversed either within the esc setup or by changing motor wires around.
                    • JPriami
                      N4FOX
                      • 1675
                      Thanks Steven. There is one gentleman on here who had his 34 inch cat with the same motors up to 66mph.
                      • martin
                        • 2869
                        Are you able to get away with 4s on the stock 70amp esc because you keep mainly to short striaght run bursts at maximum speeds. Martin.
                        • JPriami
                          N4FOX
                          • 1675
                          All I know is what works for me and what you see in the video. The stock esc's and stock motors also the 380 9xl motors will handle 4s packs. But running 40mm props and 9xls is a hot setup. I wouldn't recommend running WOT for prolonged amounts of time.
                          • Karfrik
                            • Jun 2009
                            • 1177
                            Where did you get those sunglasses with camera?....i need those for my solo runs!!...LMK,...thanks,...Albert
                            • Brushless01
                              • Apr 2010
                              • 487
                              Where do u get the boat ??
