SV27 on 6s flying at 55.8mph and two awesome flips.
  • ms71171
    • 127
    Not exactly my best run but this is a good example of what the SV27 does over 50. I was running 2 2200 mah batteries while I wait on my 5000mah 3s and it was way too light. The 2nd pass from left to right it hits 55.8 on my garmin.
    32" Toysport Triton, stepped hull, no flood chamber, 1515 1.5y NEU 1500kv motor, 180a Turnigy SC - running 6S, Aquacraft SV27 - currently running UL1 motor on 4S. Boat has seen 59mph running Feigao 11XL on 6S, 17" Velocity Minicat
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    Not sure if this youtube link works properly, cant see any SV videos...
    Canada
    • ms71171
      • 127
      Ok link fixed
      • keithbradley
        • 3671
        I cant see a video either...I have ran into this before when someone posts a link from a phone though. I think it has something to do with posting a link from the mobile site.
        To the OP: I ran my supervee with a few different prop/motor/esc combos on 6s. Even a 1515-1y on 6s at one time. I can tell you for sure you will be surprised at the difference in power a larger battery will make. It will be like a whole nother boat with the 5000's. Im surprised you didnt puff the 2200's.
        www.keithbradleyboats.com
        • ms71171
          • 127
          Ok, how bout now?
          • ms71171
            • 127
            I have Turnigy 5000Mah 40C 3S on the way. I have run it once with a new set of Turnigy 5000Mah 25C's, but after the first run, once of the brand new packs lost all continuity. Now, when I hook it to the charger, it fails the battery check and says "Broken Connection".
            Anyways, I'm shooting for 60mph and may get there if I get my GPS and batteries positioned better. I was running a X642 in the video and have a x646 which should be a blast with the 5000's.
            • keithbradley
              • 3671
              The light weight must be helping her skip across the water like that when you flip. Every time I flip my sv it catches somewhere and slams.
              It looks really good with that prop and you might have a decent chance of keeping it in the water with more battery weight. I think you'll have a hard time with the x646. Mine liked the smaller props better. It flipped too easily with anything over a 42mm.
              Heres mine with an x445 on 4s:
              • keithbradley
                • 3671
                I've had that problem with turnigys. There is a circuit board where the cells are series'ed together via traces with solder. Too high of current draw and it will just open one of those traces.
