my brushless proboat apache 24
  • SweetZ28
    • 1535
    I am happy with it now!
    WWW.PPRSLOTS.COM
  • Rumdog
    • 6667
    Smooth running!
      • 9481
      Looks good man!
      did you check temps? I bet you could run a bit bigger prop
      • SweetZ28
        • 1535
        Looks good man!
        Thanks I have the 3300KV motor and my prop was 31.5mm the esc ws 79deg and motor bairly over 100 deg but my 3S battery got hot 130 to 135deg but i ran it till 3.4 lipo cut off...I am going to grind a cf prop down to 30mm or 29mm it will make the battery run cooler ... and you never know it could get faster also.
        If it don't work out well i could just run it a min or so less and it should be ok.
        Z
        WWW.PPRSLOTS.COM
          • 9481
          sounds a little odd to me that your esc is cold and your motor warm but your battery is hot?
          • SweetZ28
            • 1535
            Yea i know ... well i got the 3000 lipos on e-bay for $22.00 shipped each they say there 35C?
            here is the link to them..
            http://cgi.ebay.com/EC-POWER-3000mAh...item2a0286dce4
            WWW.PPRSLOTS.COM
            • Rumdog
              • 6667
              take temps 2 minutes in. If the batt is cool, youre prob running too long.
              • Jesse J
                scale FE enthusiast
                • 7818
                runs real nice, yes good batts are good. might go 2P if possible to get you mah ~ 5000 or so. Really like how she rides, congrats. could you post some shots of the hardware?
                J
                "Look good doin' it"
                See the fleet
                • SweetZ28
                  • 1535
                  J
                  Hi thanks i think i posted some shots in the apache section i will see if i can get the URLs to it for you.
                  THANKS
                  Hi here look through this there are some photos there are more in different spots in the apache section also.
                  http://forums.offshoreelectrics.com/...ad.php?t=10491
                  WWW.PPRSLOTS.COM
                    • 9481
                    that was my first thought, possibly getting hot running down to lvc?
                    • SweetZ28
                      • 1535
                      Yes most likely but i am going to try the new 29mm prop and see how that goes...it may cavatate to much and if that happens back to 31mm and just time my run until lipo cut off comes on and subtract a min and i think i will be good.
                      WWW.PPRSLOTS.COM
                        • 9481
                        I'm thinking, the 29 will just spinnn and spinnn
                        • SweetZ28
                          • 1535
                          We will see I have to try it.
                          Z28
                          WWW.PPRSLOTS.COM
                          • FE Wannabe
                            • Jul 2007
                            • 654
                            Z28,
                            Glad to see that it is running good! Those Apache's can be fun once you get them moving twice the stock speed or better.
                            How is it turning for you under power? I am supposing a lot better than with the outdrive doing the turning. I know mine was hooking badly before I went to the separate rudder. I think I may need to trim a little of the bottom of my rudder, because it is pulling a little to the right when going straight, and I think it may be the extra drag of the long rudder.
                            Have fun with the fine tuning!
                            Brad
                            SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
                              • 9481
                              Z28
                              Love to know..
                              keep us up to date
