H&M Shovel full speed into shore
  • Doug Smock
    • 5359
    Originally posted by DISAR View Post
    I had a similar situation (boat out of control) with a Hydra HV240 because of low RX pack. I tested again at home and found out that if the TX or RX bats are low the hydra stays at that power (whatever maybe, worst scenario is full throttle) for about 10 secs, then it stops.
    Yep.
    I was investigating a runaway I had early this year, (never found the cause) and discovered that the Hydra series controls will hold their last command for approx. six seconds in the event of a RX failure.
    Six seconds is a LONG time at WOT.
    The SV and UL-1 controls I tested hold their last command for approx. 3 sec.
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • properchopper
      rcgoatbuild@snotmail.com
      • 7708
      Originally posted by D.Smock View Post
      Yep.
      Doug
      That seemed to be my experience; no steering indicated a broken link between the Tx & Rx & the motor did stop after the boat came to rest.
      • DISAR
        • Aug 2007
        • 1137
        http://www.rcfastboats.com/
        • sailr
          • Nov 2007
          • 7128
          I have three tactic transmitters. One day, while using the same transmitter on two different boats, with the boat sitting still in the water, they just took off, both hitting the shore and causing some damage. BRAND NEW batteries in the Tx.
          I am now using just one transmitter for all my boats (about ten at the moment) with no problems. Now the question is, which of the other two transmitters is the bad one! haha. guess I need to put a receiver in one of my sailboats and then try the other two transmitters to ferret out the bad one. At least if it hits the shore it won't be with much of a THUD!
          Good luck tracking down your problem. Let us know!
          Mini Cat Racing USA
          www.minicatracingusa.com
