Ferrari cat build and video.
  • FastVee
    • 659
    Here it is, hope that you like it!
    20/30c lipos s220 and s215.
    If you want to watch just the video part, fast forward to 2:10 (the best part is at 5:25 )
    Took many more videos, but I guess 10 minutes is long enough to publish.
    32" Catamaran
    Futaba 3PM 2.4GHZ Fasst! radio
    Feigao 8XL
    Hi-Model 200A ESC with Radio Shack thermal paste,Etti cooling plate and waterproofed with 3M DP270 epoxy.
    4S Li-Po (2X2S1P)
    Thrust bearing(5mm Tamiya)
    .150 Flex cable, 3/16 prop shaft,Grim racer speed grease,Octura bullet nut
    OSE strut/rudder
    S215(bar cut) and S220 Propellers
    Traxxas 2070 digital servo
    Dubro steering linkages
    HOTR motor and servo mounts(I did modify them)
    3M velcro battery straps
    Pool noodle bits for flotation
    Pate
    www.youtube.com/rangerpate
  • FastVee
    • 659
    One more, 30/40c lipos and s215 (unedited clip) http://www.vimeo.com/6556717
    If you have account in Vimeo, you can download the better quality clip from lower right corner of that video page.
    • wolf IV
      • 1050
      looks good, have you gps'ed her yet?
      http://www.youtube.com/watch?v=e-npTLBHefY
      • Heath M
        • Mar 2008
        • 865
        excellent,
        whats the hull and setup?
        Brisbane,QLD, Aussie
        • FastVee
          • 659
          Wolf, sorry No gps yet, looks about 45mph to me.
          Heath, the hull is from head of the river, http://forums.offshoreelectrics.com/...ead.php?t=5487
          Sorry ,I forgot to add the setup on first post, added there now.
          Pate
          • bea5017
            • Aug 2009
            • 173
            i am thinkin bout gettin this hull was it really nesicary to carbon the inside to stifen it?
            • FastVee
              • 659
              no, but it is very light and I belive that it would snap in half if it flips speeds over 35mph. -add some fiberglass if carbon is the problem?
              • Jeff Wohlt
                • 2740
                The seams are the issue. Use some FG seamn tape and run where you can. Then fill the sponson nose tips with foam to make it strong.
                Hope to have mine running this weekend but orders to complete.
                www.rcraceboat.com
                jwohlt5362@yahoo.com
                • KillerDave
                  • 370
                  I did crash at full speed... something over 50 at a guess, I know it did 68 but on that run my Li-Po blew up and split the hull in two at the front, Thanks for the tip of filling the front with foam! That's what I will do.... (when it's fixed)!!!!!!
                  HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
