Modded 27 ATOMIC
  • jetdream'n
    • Aug 2020
    • 7
    Modded 27 ATOMIC
  • NEDan
    • May 2019
    • 23
    VERY COOL!
    Well? What Motor? Prop? ESC? What is on the back of your sponsons beside the trim tabs? Autobailers? Have you ran it yet Curious as to how it handles with the TT's. I'm modifying one now also.
    • jetdream'n
      • Aug 2020
      • 7
      Leopard 2960 KV, Seaking 120 a, CNC 38 MM 1.6pitch. Yesthose are autobailers. I had to fab up trim tabs from scratch so they would fitaround them. The boat was porpoising at high-speed it seems to help.Because the boat is so skinny, it’s very unstable I have to run a small batteryin the center so it doesn’t flip in turns. I’d say With a 3s, I’m in the 45-50mph area in 100% glassy conditions. 4s is crazy fast with that small of a boat.She takes flight very easy.��
      • jetdream'n
        • Aug 2020
        • 7
        • NEDan
          • May 2019
          • 23
          Your Link doesn't work for me. 404 error. Leopard 3650 0r 60?
          I've ran mine only once on 4s and couldn't judge much as it lasted only a few min's.
          Collision resulted in an unlucky hit.
          I ordered a new hull. It seems the Rage Cat was cheaper and readily available through Amazon 2day.
          Thats an 1800kv with a 90a esc and an Octura x440
          Will try again this weekend.
          • jetdream'n
            • Aug 2020
            • 7
            3650. I had to trim the plastic leg portion of the motor mount a little to make room for the cooling jacket. Not sure why the link isn't working. Its just a short video of some speed passes.
            [ATTACH=CONFIG]170478[/ATTACH]
            [ATTACH=CONFIG]170479[/ATTACH] [ATTACH=CONFIG]170480[/ATTACH][ATTACH=CONFIG]170481[/ATTACH]
            [ATTACH=CONFIG]170482[/ATTACH]
            • KiwiBoater
              • Feb 2019
              • 11
              That looks great! How did you come by the white hull?
              • jetdream'n
                • Aug 2020
                • 7
