My mystic
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    That's nice!! Save yourselves the trouble and pass it to me. I promise I will find time to do it up!! Mine is in the build thread .....
    http://forums.offshoreelectrics.com/...c-1380mm-build
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1876
      By the way, the two part foam and carbon Kevlar cloth can be found here http://www.kintecracing.com/Building_Supplies.html
      • Skullcracken
        • May 2010
        • 728
        PWB... Hey man. We're JBS brothers!
        • Pwb201
          • 223
          Nice man!hows the build on her? I liked the Shweet deal you got I must say it was a good buy. any runs yet? Mine is currently under cunstruction as it delaminated at 85mph in 5cell cross wind took her up again.. ImageUploadedByTapatalk1348074481.703505.jpgImageUploadedByTapatalk1348074525.000151.jpgImageUploadedByTapatalk1348074654.523742.jpg
          • Skullcracken
            • May 2010
            • 728
            Originally posted by Pwb201 View Post
            Nice man!hows the build on her? I liked the Shweet deal you got I must say it was a good buy. any runs yet? Mine is currently under cunstruction as it delaminated at 85mph in 5cell cross wind took her up again.. [ATTACH]84762[/ATTACH][ATTACH]84763[/ATTACH][ATTACH]84764[/ATTACH]
            I haven't got it running yet. Its weird, I can't get the collets to hold the drives. They backout just bench testing. Mike pulled them just prior to shipping. They seem to not go far enough into the collet, and the prop shaft is flush up to the stingers. Definitely a good buy, but hasn't seen the water yet. Been tinkering with my Cintron Fightercat. The guy I bought the hull from mounted the motor mounts a little too far from the front. I can't get batteries into the sponsons.
            • PRO PAINTER
              • Nov 2011
              • 208
              Carbon fiber bulkheads made from carbon plating material from ProTec Composites would help
              Hippie's Airbrush Alley http/:www.theairbrushalley.com
              • Jersey Crewmax
                • 495
                Me too fellas! I'm trying to get someone to come with me to video but seems hard to make this happen. I wish man had 3 hands, I'd be able to make it happen than.
                Where in Jersey are you, I'd like to see this beast run and I'll gladly take a video. I'm up north in Union County but I've been to Lake Manalapan a few times.
                • Pwb201
                  • 223
                  I'm in Bergen county, usually at horseshoe lake or a private lake behind my cousins in Washington township. Skull you should leave alittle space there between shaft and drive also I would think about resetting the motor mounts if they are far infront might throw off cg, I would also invest in rear supports for your motors if they are 92mm you should put the rear support in its a must..
                  Pro painter? What is that your suggesting? Is it for my fix?
                  • Skullcracken
                    • May 2010
                    • 728
                    I figured out the problem with the collets. I took the collets apart and Mike had the brass piece inside them in backwards. The clamping ends were facing the motors.
                    • Pwb201
                      • 223
                      Yeah at first I had them in backwards and its impossible to get off I should've told you sorry bud don't think about it.
