Adding a capacitor to the Turnigy Aquastar 120 A speedy
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    My Jersey Skiff has a rather long run between the speedy and the batteries now that I found the correct CG by moving the batts to the back. Even with dedicated cooling to the SC it comes in a little too hot for comfort, so to reduce the ripple current* I'm thinking an additional cap will help . ( *Actually I prefer Ripple Strawberry but that's another story )
    Stripped the batt wires close to the SC and tinned them
    prepped cap; shrink on cap wires keeps it insulated
    soldered on SC wires
    insulated solder joints with shrink & secured with a larger band of shrink
    Nothing new here, just thought someone might be helped by this.
    Tony
  • m4a1usr
    Fast Electric Addict
    • 2036
    It can never hurt to repeat the good stuff Tony. Not sure why but OSE has boat loads of info, yet so few bother to do a search. They just ask the same questions that have been answered a hundred times.
    John
    Change is the one Constant
    • properchopper
      • 7708
      John
      John, Sad but true. I actually thought this would be too redundant to post.
      • jimi911
        • Jan 2010
        • 232
        Just finished doing that on my old C80 Cuda ... part of the reason I still have the old girl :)
        I really like the anti spark setups. Saved a lot of equipment watching my caps like a hawk and installing anti-spark on everything
        www.whittingtonracing.ca
        • sanyijr
          • 377
          Tony,
          Would you mind informing all on the benefits of adding capacitors? When needed. Capacitor bank vs single. (I know some info its on the main site, but here would be good as well)
          Any words of caution....)
          Sean
          • properchopper
            • 7708
            Originally posted by sanyijr View Post
            Tony,
            Sean
            Sean,
            I'm not qualified from the point of electrical theory to go any deeper into the issue than to say that adding capacitors, in the end result, makes the SC run cooler in certain cases. I was just one of the sheep that followed along when the "add capacitor fad" started some time ago. Those better educated in this subject may chime in.
            • jimi911
              • Jan 2010
              • 232
              Helps with heat dissipation (more/larger the caps ... better heat transfer), helps the esc handle spikes, and smooths out the flow of 'juice' through the esc.
              Wont give you greater performance past the specs of the esc, but will give you a greater measure of safety.
              • properchopper
                • 7708
                Perfectly worded. In the case of my Jersey Skiff, which due to it's design and irregular running attitude vents and unvents the prop to a large degree, the extra cap should smooth out the spikes and ripple current when this occurs, especially with my extended battery-to-SC wires.
                • jimi911
                  • Jan 2010
                  • 232
                  For those with the larger Castle HV escs, there is a cap bay that is pretty handy and easy to install. I just put one on my HV110 for a bit of extra protection. Adds some length to the setup, but its good piece of mind. This unit also has an anti-spark setup I added, which is nice on the HV rigs.
                  • properchopper
                    • 7708
                    Some more applications
                    • sanyijr
                      • 377
                      Tony,
                      so to followup on my question... Why did you only add 1 capacitor to your Aquastar? Wouldn't 2 be better? Or 4? Is there a general rule of thumb of what size/number capacitor to X cells, or amps anticipated? Or % of ESC power used to esc rating? Does that question make sense?
                      Sean
                        • 9481
                        Not at all Tony..
                        I thank God for posts like yours and the great info for us to use..
                        • properchopper
                          • 7708
                          Tony,
                          Sean
                          Sean, I'm "electronic theory challanged" so here's my "rule of thumb" :
                          1] : Measure thumb :
                          2] : Find capacitor of similar dimensions :
                          3] : count thumbs
                          4] : Install thusly : # thumbs = # capacitors ( if you're one of those people that are "all thumbs", buy extra capacitors)
                          Seriously, I hope someone with more grasp of this answers your question. It's been discussed & posted before on OSE.
                          Enjoy,
                          Tony
                          • sanyijr
                            • 377
                            Tony,
                            I appreciate your literal interpretation..... But your math worries me a bit
                            But I do see you are using 25V caps. Can you (or anyone since Tony will use a differnet rule of thirds or something creative....Not that there is anyting wrong with that) give any advice on the Voltage capacity on the caps? I assume Capacitor voltage should never be less than the total battery voltage.... Is that a safe bet?
                            • Steven Vaccaro
                              Administrator
                              • 8934
                              John
                              I really have to work on going a better job on categorizing helpful tips.
                              Steven Vaccaro
