water proofing the Seaking 180A ESC ... my way
  • Bigbore
    • 179
    I found out that with my previous 180A ESC the water passed under the cooler in this spot:
    So I've decide to seal my new ESC with 3m Dp270 Clear Epoxy.
    This is the ESC just out of the box:
    This is what I've done to make it water proof
    I've started with the epoxy as it is on this side:
  • Bigbore
    • 179
    This stuff need some temperature to polymerize. . . At least 30°C and also it has a very low viscosity and don't stay were I put it.
    So I've experimented to thicken the resin with these microballoons: http://www.offshoreelectrics.com/search.php
    The yellow spots are with the microballoons and I needed the yellow scotch anyway
    • Bigbore
      • 179
      • Griff
        • Jul 2011
        • 69
        looks like a nice neat job
        • HydroMike
          • Oct 2011
          • 338
          I'm new at this but what about the heat that is generated.
          • MR2NR
            Jet Stream EP
            • Sep 2011
            • 160
            As long has he has adequate cool water flow I'd say he will be fine. I would have used LET but nice job!!
            Kyosho K.I.T.T.
            • Bigbore
              • 179
              Max temp so far was 140F and everything is OK.
              What is LET?
              • Boaterguy
                • 1779
                liquid electrical tape, it comes in spray and brush on.
                diesel used it and ran a receiver in a bottle of water to prove how good it works!
                • JackBlack26
                  • May 2007
                  • 904
                  I used "plastic dip" Works great and is easy to remove if necessary.
                  Looks great though! Good job.
