A Method for Assembling Flex Shafts using Loctite
This is a sticky topic.
  • Steven Vaccaro
    Administrator
    • 8934
    If you do this, is there any benefit to using 3/16" cable when it terminates with .150" anyway??
    Yes because if you notice all the 3/16 assemblies the flex cable is hard soldered the last 1/4 to 1/2" to the prop shaft.
    Steven Vaccaro
      I'm sorry. I was under the impression that someone was trying to use Loctite for this.
      • Steven Vaccaro
        Administrator
        • 8934
        I agree, as far as I know loctite can't be used with those.
        Steven Vaccaro
        • CraigP
          • May 2017
          • 1464
          Of course there is if you braze the two pieces and re-join the outside braids with molten material. It is then centerless precision ground back to 3/16”. I wouldn’t trust a glued assembly in this application. Many do it, but I put my faith in metal!
          • martin
            • 2881
            When you braze a 3/16" flex in the method I outlined above both the 150 part of the flex is brazed into the stub hole & the butted part of the 3/16 joint is brazed as well. You simply cant use Loctite on this type of joint where it is 3/16" flex going onto a 3/16" stub. Chopped up pieces of brazing rod along with flux is put down into the bored hole in the stub before inserting the flex prior to heating the assembly, further rod is added at the butted joint to complete the brazing job.
            • CraigP
              • May 2017
              • 1464
              The chopped pieces is interesting... I use the hole as a molten metal pot, then bring the flex in from the top, slowly heating it as I insert into the hole. There is extra in there that will flow out around the sides, and some of that is what attaches to the outer cut strands. The procedures sound pretty close to me...
              • martin
                • 2881
                Yep same sort of idea, you must also keep the torch flame towards the stub & let the heat travel to the flex otherwise you risk getting the flex to hot if you put to much flame directly on the flex for to long & annealing the flex.
                  I'm a bit confused, nothing new.
                  I see three tubes not two for keeping the cable centered.
                  Can you fill in the blank void in my melon head?
                    If Loctite gets higher than the stub it seems to stay tacky. Should I clean it off or leave it? Just one cable I messed up.
                    • Steven Vaccaro
                      Administrator
                      • 8934
                      clean off any outside of the stub
                      Steven Vaccaro
                      • rearwheelin
                        • 2101
                        I have extra piano wire if you need some to make me drive cables lol I actually just threw away brand new wire that I didn’t need lol
                        --Albert Einstein
                        • rearwheelin
                          • 2101
                          I plan on soldering my own just to experiment. I might be Steve’s new supply chain lol
                          --Albert Einstein
