Darin's Method for Making Paralelling Adapters
  • Darin Jordan
    • 8332
    Thought I'd share my method of making Paralleling Adapters. These are made with 5.5mm contacts from, where else? OffshoreElectrics.com.
    I use Copper Tubing to provide a solid joining of the three contacts.
    I drill an appropriate sized hole all the way through the middle contact, and just through one side of each of the outside, then press them together.
    Then I solder them together, filling in the wire barrels as well, and cover with heat-shrink. Pretty basic. Seem to work very well.
    Darin E. Jordan - Renton, WA
  • shua
    • Apr 2015
    • 479
    A very simple and most helpful post!
    I would never have thought of the copper tube to aid in soldering and making a stronger assembly.
    Thanks!
    • T.S.Davis
      • 6228
      I made some similar for 8mm connectors but I used solid copper grounding wire in a huge diameter. Nearly filled the 8mm sockets.
      Noisy person
      • Darin Jordan
        • 8332
        Yes. I really wasn't thinking of the copper as "the" conductor... just "a" conductor that helps hold things together. The solder, and touching contacts, are what I was after. Just after making a few of these with JUST the contacts, I got tired of fighting the soldering! One could easily do the same thing with just wire between them.
        Been using these for a couple of seasons now and they seem to work really well. Bench testing shows them to have all the conductivity that I'm after.
        • T.S.Davis
          • 6228
          I always wondered about that. I use Stabrite so as much silver as I can get but still am relying heavily on solder to conduct. I don't think of solder as the best conductor.
          I've used actual strand wire too. Sure makes it easier to plug in some of these monstrosities I have going with a little flex.
          Noisy person
          • longballlumber
            • 3119
            While I understand why these adapters are popular and the standard set-up for 2P configurations, I have adopted splicing 2P wires onto the controller (pigtail). Much easier to solder and you eliminate and extra connectors sets. I don't have a picture, but it's work great even on my P-Limited boats that use OEM Aquacraft controllers.
            don't need 2P but need the controller, I simply secure and cap off the extra connections with rubber protector boots.
            Just another way to skin the cat.
            • langevn
              • Mar 2015
              • 214
              Do you sell the if so how much
              Sent from my SGH-I337M using Tapatalk
              • zooma
                Local club FE racer
                • May 2014
                • 652
                What size heat shrink tubing? From where?
                Ron - The Villages, FL
                • Darin Jordan
                  • 8332
                  It's standard 3/8" heat-shrink (like what comes from OSE with the contacts). I use a pair of needle-nose pliers up inside it to stretch it open wider to fit over the larger section. There are smaller pieces over the individual female contacts, and I double layered the black over the larger section.
                  • T.S.Davis
                    • 6228
                    Tom does his that way too. So much easier to deal with and less resistance to boot.
                    Darin, try this stuff some time. It's silicon with no glue. Stick to itself and has a higher melting point than shrink tube. I use it on everything sparky.
                    Uline stocks a wide selection of Silicone Self-Fusing Tape. Order by 6 p.m. for same day shipping. Huge Catalog! Over 45,000 products in stock. 14 locations across USA, Canada and Mexico for fast delivery of Silicone Self-Fusing Tape.
                    Noisy person
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2520
                      Cool! Thanks Darin!!!
