quick and easy flooded stuffing tube
    I havent built a mono just yet but I had some ideas on how I would do the drive tube and have it adjustable. I've seen people do a flooded tube with a boot on the interior end, good idea but I wanted to be different. So I used an idea from my cat builds. I like the idea of being able to remove the drive tube if I need to so I make a slip joint. I did the same on this little mono. This thing came with a strut.....but it was just for looks. I could not believe it when I figured out it was non adjustable from the factory...who does that? Lmao! Anyway I made a short one as it does need much adjustment. Here's what I did:
    Ripped out the stock drive tube. Drilled a hole bigger for my brass flooded tube. Removed the epoxy from old tube.
    Then I cut my brass tube. 27/64 is what I used. Then I found a nut to fit snug in the tube. Drilled it to fit the slip tube.
    Assembled it.
    Then I filled with jb weld to hold it together. Recess the nut some, slide tube in a little and put jb weld around it.
    Slide it in and check fitment.
      I'm sure you can see why I needed to so this and upgrade to 3/16 flex at the same time. That motor you see is a good bit more power than stock.
      And finished. I point the front of the boat and poured epoxy in to hold the flooded tube in place. Thought this may be helpful in giving some ideas. In a custom built boat I would make the flooded tube a little longer but this serves it's purpose. The stuffing tube slides through it btw, put a little silicon to seal it.
      • TheShaughnessy
        • 1419
        Nice little how to. Glad you did this, read you describing it on the thread where the boot was used. I was just gonna fill the end with resin/filler and drill out a hole then put the slip tube. I like the nut to keep it centered.
          Thanks! I actually angled the tupe up slightly to help with the angle of the flex tube. I mainly did this because ive had people pm me on how to do it. Why, I have no idea because ive never done one until now. I've told them how i would do it, but now i had a reason to need to in this boat. it had a really bad negative angle on the prop that i wanted to level out. Well when i tried to angle it, the drive tube broke. so hence the reason for this thread. i'm sure theres a better way, just wanted to throw some ideas out there. I'm fine with anyone posting in here how they did thiers.
          • TheShaughnessy
            • 1419
            Are you really gonna run that motor In there?
            • Luck as a Constant
              Make Total Destroy
              • Mar 2014
              • 1952
              Looks good. But with a flood chamber that short, how much adjustment do you actually get?
              I'm not sure how long it actually is, or if the nut acts as a pivot point in some way?
              I totally understand this is just a test of the idea, and given the opportunity you would make it longer....
                yes, why?
                  I dont need much adjustment at all. i'm just playing around with this boat. the tube actually slide so i can add negative or postive prop angle and about 3/16" up and down stru adjustment. better than nothing for sure. If this thing does as well as i hope, i may rip the interior out and redo it travis style. lol
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    Haha no doubt man.
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      I have a habit of completely rebuilding factory crap. This was a factory white ibanez. Can't have that tho lol
                      • runzwithsizorz
                        • Jan 2009
                        • 856
                        I too, liked the idea of being able to remove the drive tube if I need to, maybe going from no liner, to lined. On a mono however, I still wanted to use a stinger. Using button head screws, and J B wield I
                        secured a piece of sheet metal to the stinger. Even though the motor is mounted far forward, I still needed to angle the tube up. I did this by shaping a small block of wood, and glued it to the hull. The
                        tube was secured to the block with a plastic pipe hanger, 2 small screws, and A LOT of glue, not pretty, but it ain't going anywhere, a radio box goes over it. Used the largest rubber boot Steven sells, and a couple of clamps.
                        The T bar oiler adjusts up down, left, and right, and locks the stuffing tube in place.
                        • TheShaughnessy
                          • 1419
                          I thought about keeping the stinger on my mono build but I was like, not enough meat on this stinger, now I see how you did it.
                            What's wrong with My motor choice? Lol
                            • runzwithsizorz
                              • Jan 2009
                              • 856
                              In my high school auto shop class, we put a 427 in the back seat of a Corvair, so I would say, not a darn thing.
