Ideas on Building a Reliable BL System by ReddyWatts.
This is a sticky topic.
  • ReddyWatts
    • 1700
    Steps for building a Fast Electric
    1. Build a boat stand.
    2. Drill and mount the strut and rudder. Might need to strengthen the transom.
    3. Drill holes for water-cooling inlet and outlet.
    4. Install radio antenna.
    5. Install water jacket and thrust bearing on motor.
    6. Place all equipment in boat to find the desired center of gravity. Move the motor around, so that you after you mount the motor, you will still be able to move the batteries and keep the COG in the desired range. 27-33%
    7. Epoxy motor mount to hull. Might need to strengthen the inside bottom of hull.
    8. Decide where to cut hole/slot for flex drive tube.
    9. Decide where to drill hole for rudder/servo connecting rod.
    10. Bend, then cut tubing to fit between strut and motor. Leave less than ½ inch gap between motor coupler and tube. Start with strut bottom 1/8 above the bottom of hull. Raise it during water tests to desired height. Use heat shrink on strut connection.
    11. Cut flex cable to length needed.
    12. Install flex cable and check alignment at motor and strut. One sweeping bend is better. Epoxy tube into hull.
    13. Remove all parts.
    14. Paint the hull.
    15. Add floatation to hull and hatch.
    16. Reinstall all parts and seal.
    17. Mount servo and use rubber boot to waterproof connecting rod and hole.
    18. Lubricate drive line.
    19. Install radio and battery switch if used.
    20. Install battery tie downs.
    21. Install water-cooling hoses. Use cable ties on all connections. pressure test for leaks.
    22. Test hull in bath tub for water leaks.
    23. Program and test ESC.
    24. Check motor rotation.
    25. Check for receiver glitching.
    26. Check everything for tightness, use blue thread lock on all threads.
    27. Use tape to seal the hatch.
    ReddyWatts fleet photo
    • ReddyWatts
      • 1700
      FE setups "Big Picture"
      I hope by showing a structure of setups you will see the "Big Picture" for a better understanding of Fast Electrics.
      There are to many variables for this data to fit all the different hull and motor loads. Many setups will fall outside this general information guideline.
      FE SETUPS
      --hull size /--------Cells---------/ ----Motor Kv----- / -------Prop Size------/---Type ESC---/-BEC-/ESC Amp Rating
      17”- 24” / 2s LiPo or 6 cell NiMh / 5500 -3200Kv / 30mm - 40mm Diam. / Low Voltage / Avail. / 120 amp
      20"-27" / 3s LiPo or 8 cell NiMh / 3500-2500kv / 35mm – 42mm Diam. / Low Voltage / Avail. / 120 amp
      24”-29” / 4s LiPo or 12 cell NiMh /2650-1600Kv /37mm - 46mm Diam. / Low Voltage / Avail~Disc / 120-240 amp
      26”-32" / 6s LiPo or 18 cell NiMh /1800-1100Kv /40mm - 52mm Diam. / Low or High / Disc. / 120-180-240 amp
      30"- 36" / 8s LiPo or 24 cell NiMh / 1350-800Kv /45mm – 55mm Diam. / High Voltage / N/A / 180-240 amp
      34" - 42" / 10s LiPo or 30 cell NiMh / 1100-600Kv /47mm + Diameter / High Voltage / N/A / 180-240 amp
      38" - 46" / 12s LiPo or 36 cell NiMh / 900-550Kv / 50mm + Diameter / High Voltage / N/A / 240 amp
      Always start testing with a small prop and work up to your desired amp readings!
      HULL SIZE AND OSE MOTORS
      This is a general guideline for the motors OSE sells. I know it is hard for this to cover all selections, since FE setups can be complex and extend over a wide range of extremes. Remember this is more for conservative setups to help new guys get started.
      hull size…..... /…...... Neu….... /….. Feigao.540…../Feigao 580/...700SC../.SV27./.Proboat./..Ammo../.380.
      <<"-20"....../.....1506........../.......Fiegao.S......./................./................./......../............../.............../.380 L
      17”-24”…../….. 1506,1509./…..Feigao S-L…...../…............../................./......../............../................/........
      20"-27"…../….. 1509,1512./…..Feigao L-XL...../….............../...700SC../.SV27./.Proboat./..Ammo../........
      24”-29”…../…..1512,1515../…..Feigao XL…...../….............../...700SC../.SV27./.Proboat./..Ammo../.......
      26”-32"…../.....1512,1515../…..Feigao XL….../….............../.,..700SC../.SV27./.ProBoat./............./........
      30"-36"…../….. 1515,1521./…........…………..../….. 580L...../.............../........../.............../............./........
      34"-42"…../….. 1521,1527. /…........………..…/….. 580L...../................/........./................/............./........
      38"-46"…../…..1527,2215. /….. ......……..……/................../................./........./................/............./........
      40"-60"..../.......2230......./Little Screamer 63mm outrunner/
      MOTOR MAXIMUM WATT RATINGS.
      Always look at the maximum WATTS the motor is rated to handle. The heat will kill the magnets and possibly the controller if you get it to HOT.
      Continuous rating/ 30 second rating
      Neu -
      1506 - 700 watts/ 1500 watts
      1509 - 1000 watts/ 2000 watts
      1512 - 1200 watts/ 2500 watts
      1515 - 1500 watts/ 2700 watts
      1521 - 1700 watts/ 3000 watts
      1527 - 2100 watts/ 3300 watts
      2215 - 3000 watts/ 5000 watts
      2230 - 6000 watts/ 10000 watts
      Feigao
      580L - 1800 watts/
      540 XL - 800 watts/ 1600 watts
      540L - 600 watts/ 1300 watts
      540S - 450 watts/ 1000 watts
      380L - 450 watts/ 1000 watts
      SV - BlackJack 800 watts/ 1400 watts
      Ammo 2300 - 700 watts/ 1400 watts
      700sc - 650 watts
      Volts (X) Amps = Watts
      Always calculate your setup Watts and prop it to run close to your motors Max Amp rating. (maximum effeciency rating)
      Example:
      Specs for the motor in the BJ
      TURNIGY brushless Inrunner
      Power: 460W
      Battery Config: 3-5S
      Watts / Volts = maximum AMPS to keep motor cool - recommended by manufacturer.
      460 watts / 11.1volts = 41.4 amps max
      460 watts / 14.8 volts = 31 amps max
      460 watts / 18.5 volts = 25 amps max
      FeCalc can get you in the ballpark for loaded 2-pole motor watts and amps. It is just an estimate, but can give you a good idea of which prop to start testing with.
      The Feigao 540 motor max amps ratings are attached below.
      __________________
      • ReddyWatts
        • 1700
        Water Jacket - outlet hole placement
        ""I see that most jackets have the inlet and outlet only 90 degrees apart, and they are usually mounted with the inlet at least 45 degrees below the top. What this does is create an airlock that prevents water form getting to the top of the motor - arguably the hottest part. The UL-1 jacket as it comes on the boat is worse with both inlet and outlet side-by-side - with this configuration the top half of the motor doesn't even get water. At least mount the outlet as high as possible, meaning the top front of the motor.
        Info provided by Fluid.""
        Why take a chance of getting air pockets in the motor cooling jacket during a run? Place the water outlet at the top/front on the motor and let the air escape easily.
        Let the water flow freely through the system. Fast flowing water, turbulence and with more temperature differential results in better cooling.
        • Punisher 67
          Ignore list member #67
          • 1481
          Steven and Reddy as much usefull info as you have here for me nothing speaks as much volumes as a well placed thought out boat setup picture , before I engage any build I research many examples of that build and assess all angles and every aspect of that setup with as many examples as possible . I am a firm advocate of as many build setup pictures as one can take . for me the bulk of my learning has been through pictures , pictures of failed setups are every bit as usefull as pictures of winning setups , weather you build is a success or failure the info you supply is equally important
          • ReddyWatts
            • 1700
            OSE's - FE Setups - Interactive Illustrators
            These are great tools for a better understanding of FE setup connections.
            System Wiring Illustrator
            Lipo Connection Illustrator
            • exotica
              • 159
              ...what a great thread!
              • ReddyWatts
                • 1700
                Octura Prop Pitch
                Thought this might help when looking for the next prop to try. I listed some Octura props with increasing pitch. This may show why going to a smaller diameter prop with more pitch or more blades can be faster. More blades means less slippage under heavier load, can be more effecient.
                PROP Pitch/inches
                X437/3-- 2.072
                X438---- 2.100
                X440---- 2.198
                X440/3-- 2.198
                Y536---- 2.200
                Y537/3-- 2.279
                X442---- 2.310
                X637---- 2.368
                X445---- 2.478
                X640---- 2.512
                X447---- 2.590
                X447/3-- 2.590
                X642---- 2.640
                M545---- 2.655
                X448---- 2.660
                X450---- 2.758
                X450/3-- 2.758
                X645---- 2.832
                Y547---- 2.849
                X548---- 2.850
                X452---- 2.870
                X452/3-- 2.870
                X646---- 2.896
                X646/3-- 2.896
                X455---- 3.038
                X455/3-- 3.038
                X648---- 3.040
                X457---- 3.136
                X457/3-- 3.136
                M650---- 3.190
                X460---- 3.304
                Y557---- 3.449
                X560---- 3.540
                X427---- 1.498 0.125
                X430---- 1.652
                X431---- 1.708
                X432---- 1.764
                Y531---- 1.877
                X435---- 1.932
                X632---- 2.016
                Y534---- 2.059
                Y535---- 2.125
                • ReddyWatts
                  • 1700
                  Waveform of a Brushless Motor ESC.
                  This video shows how an ESC uses a PWM waveform to control motor speed. It simulates an AC sine wave using positive and negative DC pulses. Notice how it changes the DC pulse widths but keeps a constant peak voltage during the complete throttle range. The peak voltage remains at your battery pack voltage.
                  Why it is best to run at full throttle.
                  A speed controller controls power to the motor by turning full throttle current on and off really fast, 11 to 13 thousand times per second (Pulse Width Modulation or PWM). The percentage of each on/off pulse that is off compared to the part that is on determines how much power the motor sees. I.E. With a pulse that is 50% off and 50% on the motor will see 50% power*. Because each on pulse is 100% of full throttle current, a system set to pull 20 amps at full throttle through a Phoenix 10 will not last if you are throttled back to the point where you only see 10 amps on a wattmeter. The ESC in this case is still switching 20 amps, which it can’t do for long. Because an electric motor will always to try to pull as much power as is available to get to its rpm (volts times Kv), when you are running the motor below its Kv speed by switching power on an off, each on pulse will actually be way over the full throttle amp draw. That is why ESCs work harder at partial throttle than full throttle and why we underrate our ESCs. We underrate not so they can handle more current than their rating at full throttle, but so they can handle extended partial throttle operation with no problems. CC
                  An amp is measured by how many electrons pass a point on a wire in one second. The narrower pulse current that is used by the ESC output during half throttle will have a higher peak current but read less on the input ammeter because it is seeing less passing electrons for the same period of time as it would at full throttle using wider pulses. This is why you dont see the high amps on the input side
                  m4a1user; What happens at low throttle is that the FET goes into the linear mode for a larger percentage of the on-time. That means the FET spends more time heating than it should - and hot FETs have more resistance, meaning next time they are in linear mode, they will heat up even hotter. At the same time, the motor is at lower RPM and therefore pulling more amps (a stalled motor will draw the maximum current).
                  You can get a lower RPM (ie, a lower average voltage) at maximum duty cycle only by lowering the input voltage. The speed control will run better with a lower input voltage even though it may be passing more amps simply because there will be less time for the FETs to be in linear mode. It is not an exaggeration to say that the FET may have 10X or more resistance when in linear mode. Heat generated is directly related to resistance.
                  Thank you Andy Kunz for very simply explaining this phenom to me so I can share this with fellow RC'ers
                  I hope this helps to clarify what PWM means and why it is better to run it wide open, than half throttle. The peak amps and esc resistance in the esc go up causing more heat at half throttle. Less work, stress and heat on the FETS running at WOT.
                  • ReddyWatts
                    • 1700
                    Volt/KV Chart
                    Posted by Detox
                    • ReddyWatts
                      • 1700
                      Handy Fraction/Decimal/Metric Conversion Chart
                      Handy chart posted by Ray R
                      FractionDecimalChart[1].pdf
                      • HydroMike
                        • Oct 2011
                        • 331
                        Cool alot of nice info thanks alot
                        • mxrb18
                          • Jul 2019
                          • 53
                          FE SETUPS
                          Neu -
                          Feigao
                          580L - 1800 watts/
                          700sc - 650 watts
                          Example:
                          Power: 460W
                          __________________
                          Do you have any idea what a suitable setup would be for a 72" CRC5000 Cat? I was considering a dual 12S setup with Tp-5680 (600kV 5Y, 800kV 4Y, or 1070kV 3Y) motors, twin ZTW Seal 300A Esc's, and 4 6S 5000maH 70C batteries (12S per motor). Any info would be awesome. I just need to determine the right motor setup to get on plane well but still achieve really good top end speed. Thank you
