painting question
  • MARKBRENNAN
    • 395
    painting question
    I just painted my bby scat and the paint came ou rough and dry. Can you guys tell me what i did wrong.
    • 7651
    Temperature, humidity. These are big players. Possibly old paint? Clear over it when conditions improve.
    • MARKBRENNAN
      • 395
      Could i sand this back down then repaint it again.
      • egneg
        • 4664
        Yes
        IMPBA 20481S D-12
          • 7651
          I would wetsand and repaint. No need to sand it all off.
          • MARKBRENNAN
            • 395
            What's a good tempsure to paint this
            • revoltrunner
              • May 2014
              • 646
              also if your to far away from the surface your painting
              with the spray gun/spray can you can get a dry rough coat.
                • 7651
                Somewhere's between 15-25 degrees Celsius.
                • MARKBRENNAN
                  • 395
                  When you wetsand does the paint get smooth or does it fade.
                    • 7651
                    It just smoothes it. The paint remains the 'paint color' till it gets thin. The sanding will give the next coat something to bond to. Start with 320, then 400, and could go to 600 depending on the paint and whether it shows the scratches from the 400.
                    • MARKBRENNAN
                      • 395
                      do i need to wipe off after i wetsand.
                        • 7651
                        Yes, I wipe and rinse well. And often.
                        • rdcracer
                          • Jan 2014
                          • 306
                          What were you painting with? If it is a gun it could be the mix of reducer airflow ect. If can I find if I sit the can in a tub of sink of hot water for awhile before I paint it flows better.
                          Blackjack 29. Deltaforce 33. Cheetah twin, Insane FE30
                          1/10 1970 PaynPak, Aeromarine Jersey Skiff
                          • RCBoaterGuy
                            • Dec 2014
                            • 203
                            ...I find if I sit the can in a tub of sink of hot water for awhile before I paint it flows better...
                            I do that with rattle cans, really makes a difference.
                            AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
                            Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
                            Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The Road
                            • rdcracer
                              • Jan 2014
                              • 306
                              I didnt make that clear but I meant Rattle cans. I purchased an inexpensive compressor and cheap paint gun at Harbor Freight and I paint most of my stuff that way. I have an automotive paint supply nearby and you can pick and choose almost any color. They will mix 1/2 pint for me and most colors are about 10-12 dollars which goes a long way. Paint comes out much better than rattle cans and the clear coat is awesome.
