Number cells/Motor Kv/Prop Size/Hull Size
  • ReddyWatts
    • 1756
    What about a spreadsheet to help users decide on a build?
    "Updated" with Lipo and esc amp ratings. There are too many variables for this to be exact for all of the different hull and motor loads. Many setups will fall outside of this general data spreadsheet. Just hope this gives you a better understanding of FE for designing successful setups.
    --hull size /--------Cells---------/ ----Motor Kv----- / -------Prop Size------/---Type ESC---/-BEC-/ESC Amp Rating
    17”- 24” / 2s LiPo or 6 cell NiMh / 5500 -3200Kv / 30mm - 40mm Diam. / Low Voltage / Avail. / 120 amp
    20"-27" / 3s LiPo or 8 cell NiMh / 3500-2500kv / 35mm – 42mm Diam. / Low Voltage / Avail. / 120 amp
    24”-29” / 4s LiPo or 12 cell NiMh /2650-1600Kv /37mm - 46mm Diam. / Low Voltage / Avail~Disc / 120-240 amp
    26”-32" / 6s LiPo or 18 cell NiMh /1800-1100Kv /40mm - 52mm Diam. / Low or High / Disc. / 120-180-240 amp
    30"- 36" / 8s LiPo or 24 cell NiMh / 1350-800Kv /45mm – 55mm Diam. / High Voltage / N/A / 180-240 amp
    34" - 42" / 10s LiPo or 30 cell NiMh / 1100-600Kv /47mm + Diameter / High Voltage / N/A / 180-240 amp
    38" - 46" / 12s LiPo or 36 cell NiMh / 900-550Kv / 50mm + Diameter / High Voltage / N/A / 240 amp
    Always start testing with a small prop and work up to your desired amp readings!
    HULL SIZE AND OSE MOTORS
    This is a general guideline for the motors OSE sells. I know it is hard for this to cover all selections, since FE setups can be complex and extend over a wide range of extremes. Remember this is more for conservative setups to help new guys get started.
    hull size…..... /…...... Neu….... /….. Feigao.540…../Feigao 580/...700SC../.SV27./.Proboat./..Ammo../.380.
    <<"-20"....../.....1506........../.......Fiegao.S......./................./................./......../............../.............../.380 L
    17”-24”…../….. 1506,1509./…..Feigao S-L…...../…............../................./......../............../................/........
    20"-27"…../….. 1509,1512./…..Feigao L-XL...../….............../...700SC../.SV27./.Proboat./..Ammo../........
    24”-29”…../…..1512,1515../…..Feigao XL…...../….............../...700SC../.SV27./.Proboat./..Ammo../.......
    26”-32"…../.....1512,1515../…..Feigao XL….../….............../.,..700SC../.SV27./.ProBoat./............./........
    30"-36"…../….. 1515,1521./…........…………..../….. 580L...../.............../........../.............../............./........
    34"-42"…../….. 1521,1527. /…........………..…/….. 580L...../................/........./................/............./........
    38"-46"…../…..1527,2215. /….. ......……..……/................../................./........./................/............./........
    40"-60"..../.......2230......./Little Screamer 63mm outrunner/
    MOTOR MAXIMUM WATT RATINGS.
    Always look at the maximum WATTS the motor is rated to handle. The heat will kill the magnets and possibly the controller if you get it to HOT.
    Continuous rating/ 30 second rating
    Neu -
    1506 - 700 watts/ 1500 watts
    1509 - 1000 watts/ 2000 watts
    1512 - 1200 watts/ 2500 watts
    1515 - 1500 watts/ 2700 watts
    1521 - 1700 watts/ 3000 watts
    1527 - 2100 watts/ 3300 watts
    2215 - 3000 watts/ 5000 watts
    2230 - 6000 watts/ 10000 watts
    Feigao
    580L - 1800 watts/
    540 XL - 800 watts/ 1600 watts
    540L - 600 watts/ 1300 watts
    540S - 450 watts/ 1000 watts
    380L - 450 watts/ 1000 watts
    SV - BlackJack 800 watts/ 1400 watts
    Ammo 2300 - 700 watts/ 1400 watts
    700sc - 650 watts
    Volts (X) Amps = Watts
    Always calculate your setup Watts and prop it to run close to your motors Max Amp rating. (maximum effeciency rating)
    Example:
    Specs for the motor in the BJ
    TURNIGY brushless Inrunner
    Power: 460W
    Battery Config: 3-5S
    Watts / Volts = maximum AMPS to keep motor cool - recommended by manufacturer.
    460 watts / 11.1volts = 41.4 amps max
    460 watts / 14.8 volts = 31 amps max
    460 watts / 18.5 volts = 25 amps max
    FeCalc can get you in the ballpark for loaded 2-pole motor watts and amps. It is just an estimate, but can give you a good idea of which prop to start testing with.
    ReddyWatts fleet photo
  • ReddyWatts
    • 1756
    I like to try and simplify things to make brushless FE easier for the next guy.
    Very few people have experience with all of the setups. Need some input.
    Thanks, Reddy
    • tth
      • Apr 2008
      • 1600
      Good Job Reddy That's Going To Help A Lot Of People Simplify Things. I Know I Have Learned Much Needed Info From This Site. Granted I'm Thirty Yrs Old I Have Been Building Boats For Fifteen Yrs. A Little Over A Yr Ago
      I Started To Get Serious In The Boating Community. Again Thank You To Everyone That Has Helped Me In My Builds And Answered My Posts. Keep Up The Good Work Everyone.
      • G Doggett
        • 477
        Great idea Reddy.
        Good basic information to use as a starting point.
        What ever happened to the suggestion a while back, I think from Steven, for a spreadsheet of set ups that we are running that work ?
        This sort of shared info is valuable even for old farts like me who have been building boats for years.
        Graham.
        • Eyekandyboats
          • 1935
          yes
          36 inch hull run 4s on a 50+ mm prop
          EYEKANDYGRAPHICS
          www.rclipos.com
          • ED66677
            • 1300
            Can't be more clear! Great job!
            I'm personnaly just a little bit out of the table but soon will be back on proper track!!! 29" on 3S, soon 4S!
            Wouldn't it be helpfull Reddy to indicate an average amp draw for each? I mean if a new guy want to go fast with a 29" mono he first need to know that this will not be possible at 30amps but pretty much at 60-80+amps... just my thought!
            Emmanuel
            • ReddyWatts
              • 1756
              Ed, I will start looking into your idea.
              Eyekandy, what is the rest of your setup?
              Graham, I have been wondering the same thing about Stevens setup sheet. He has probably just been to busy.
              • Eyekandyboats
                • 1935
                --hull size /-------------Cells---------/ -Motor Kv--- / -------Prop Size---------
                17”- 27” / 2 cell LiPo or 6 cell NiMh / 600 -3200Kv / 27mm - 46mm Diameter
                20"-27" / 3 cell LiPo or 8 cell NiMh / 3500-2500kv / 35mm – 46mm Diameter
                24”-34” / 4 cell LiPo or 12 cell NiMh /2650-1200Kv /35mm - 55mm Diameter
                26”-40" / 6 cell LiPo or 18 cell NiMh /1900-1100Kv /35mm - 52mm Diameter
                26"- 40" / 8 cell LiPo or 24 cell NiMh / 1500-800Kv /37mm – 55mm Diameter
                30" - 44" / 10 cell LiPo or 30 cell NiMh / 1100-600Kv /37mm + Diameter
                34" - 50" / 12 cell LiPo or 36 cell NiMh / 900-450Kv /37mm + Diameter
                EYEKANDYGRAPHICS
                www.rclipos.com
                • ReddyWatts
                  • 1756
                  Thanks for your input Eyekandy.
                  That must be a typo on the 600 kv and 2S or 6 cell
                  37mm prop on a 12 s lipo- 36 cell NiMH, 34 -50 inch hull???
                  • hex-dj
                    • 240
                    Great job Reddy. Now I can have a much clear idea about the setups.
                    • ReddyWatts
                      • 1756
                      Thanks, that is what I was hoping to accomplish by showing a simplified "Big Picture".
                      • Eyekandyboats
                        • 1935
                        yeah sorry it was supposed to be 6000
                        and yes
                        EYEKANDYGRAPHICS
                        www.rclipos.com
                        • sdartt
                          • Mar 2008
                          • 97
                          Dumb Question But Here Goes
                          When you call for a 26 to 32 inch hull using 6 cell LiPo's, does that mean 2 packs with 3 LiPo's each. Thanks for the reply!
                          Jacksonville Florida
                          • ghostofpf1
                            • 399
                            Very helpful.
                            Something I had wished more of the vendors would do is give specific power source range recommendations for their hulls.....props..motors kv and mass...amp ranges for each set up.....
                            Second on the ~amp draws btw..this would be very helpful in spec'ing power components.
                            thanks much
                            Ghost
                            • Eyekandyboats
                              • 1935
                              also you BEC idea.. good but.. BEC should not be used on any model unless its a micro. you get better results with a BEC pack.
                              do you race under IMPBA or NAMBA ?
                              EYEKANDYGRAPHICS
                              www.rclipos.com
