Eagletree 150 amp to 300 amps in 15 minutes
  • jcald2000
    • 786
    How high can it go??
    I just recorded a 372 amp peak for about 2 seconds when my 6s2p sport hydro submarined on launch.
    Don't want to do that again!
    • oscarel
      • Dec 2009
      • 2373
      I was only able to get around 190 before the mod then the solder would melt off normally on one of the negative terminals. So that puts it around 380??? Did that spike have a flat top?
      • jcald2000
        • 786
        Yes!!
        • HydroMike
          • Oct 2011
          • 338
          Going to try this thanks
          • jcald2000
            • 786
            A friend of mine bought a used ET on line that used a short 8 or 10 gauge as the shunt. Remember, the resistance must be the same for the additional wire, 12 gauge only and the same distance with a good solder joint.
            • Tamelesstgr
              • Jun 2014
              • 1512
              Question, I don't have a high output charger, but I could in theory hook up my eagletree between my charger and the lipo pack I apply a charge to and then hook it up to the software in order to calibrate? My charger is capable of 5 amps max per channel.
              NEVER SATISFIED RACING
              Fine Design 32 V-Hull 4082+6s
                Two-year-old thread, and the OP hasn't logged on in five months......good luck.
                • dmitry100
                  • Mar 2015
                  • 1264
                  400 amp current sensor... https://www.sm-modellbau.de/UniLog-Stromsensor
                  • Steven Vaccaro
                    Administrator
                    • 8932
                    thats pretty nice.
                    Steven Vaccaro
                    • Tamelesstgr
                      • Jun 2014
                      • 1512
                      Just waiting on parts, I am going to use a plane propeller to simulate about a 50 amp load on the motor with my shandard ETV4 150 amp logger to track. Then I should be able to take my modded ETV3 (Will be 200 amp version when I finish the modification above) and calibrate with the same load.
                      • drwayne
                        • 3012
                        Have fwd that link to my daughter .. father's day is coming up
