Bulletproof "Quick-Change" 4" rail motor mount
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    While waiting for parts to arrive for my 32" Jersey Skiff build, the first dilemma was to come up with a motor mount that doesn't require some mini-contortions to change motors given the relatively limited inside access of this hull. A easy in / easy out design was called for that would allow quick motor replacement between heats, as the first race outing will be with spec motors that should be rather challanged with a submerged prop. Later plans call for full-house P-Class power, so to make the act of changing motors painless, I came up with a design that's a no-sweat operation. Using the extra-strong Insane front mount (which has solidly supported a 1527 Neu in a different boat) and is noticebly thicker than the adequate but mostly spec-rated OSE mount, it mounts to a plate (with a cutout to allow for bigger motor cooling jackets) that can easily be removed with four outside 4mm cap screws that thread to the right-angle pieces that stay bolted to the rails. No more frustration trying to start those balky 3mm motor screws buried inside with a mount permanently attached, or removing the four conventional rail mount bolts.`
    Hi,
    That looks like a great idea.
    Were can I buy them at ?
    I need one for a 4 1/2 rail and may be water cooled to.
    Thanks for any info.
    • properchopper
      • 7708
      Hi,
      Lenny, I just made this starting with the Insane FE30 motor mount and some aluminum angle iron and plate. Lots of drilling and tapping & some polishing. I'm likely going to replace the bottom rail-to-rail piece with CF plate to go lighter. As it sits, it weighs 4.15 oz.
        Ok thanks,
        I think I will try to mod your idea,
        For what I need in a mount, But water cooled for a outrunner to.
        Thanks for sharing the info.
        • Steven Vaccaro
          Administrator
          • 8932
          Aero makes something very similar. If you want pictures shoot me an email.
          Steven Vaccaro
          • Scott T
            • 625
            Looks good Tony. I have a similar functioning mount in my DF21 MkII, four easily accessable bolts and half of the mount and motor come right out. It could easily be flipped over for a flat bottom hull, and wooden blocks could even be used to screw it to. No problems supporting a 1717.
            Plenty of pics in my build thread if you want to have a look - http://forums.offshoreelectrics.com/...Mk2&highlight=
            Scott Tapsall
            Pine Rivers Model Powerboat Club - Facebook Page
            My Gallery
            • properchopper
              • 7708
              Scott, beautiful work overall I hear you on the rudder bracket/trim tab real estate conflict; been there lots of time myself ! The quick change mount is super ! Link ?
              ( making mine was a PIA and my apt. still has aluminum chips embedded everywhere !)
              • RandyatBBY
                • 3943
                That is a real cool way of doing it Scott! Bravo! I like the simplicity of it, and looks real strong a rear retaining ring would be eazy too.
                Randy
                BBY Racing
                • Scott T
                  • 625
                  Thanks Tony. Andrew at Fastelectrics developed that one, and they're available here - http://www.fastelectrics.com/hardware.asp Might save you some aluminium chips in the future
                  Scott Tapsall
                  My Gallery
                  • properchopper
                    • 7708
                    Thanks, Scott. I now remember seeing them some time ago. Really nice design. Next time !!
                    • CornelP
                      • 793
                      I did an easy to remove support that is now my standard... It's mostly CNC (except the threads), easy to assemble and very easy to remove/install: three screws from the top and you're done.
                      • properchopper
                        • 7708
                        Very nice !! I wish I had more than just a hacksaw, drill press & a grinder/sander.
                        • CornelP
                          • 793
                          It's actually made in a local shop on my drawings... less than 10$/set...
                          • properchopper
                            • 7708
                            Do you have a photo of the piece (on the hull) that the mount attaches to ?
                              Very nice mount,
                              Can you do a water cooled version, something like that for outrunners motors ?
                              LMK
                              Lenny D
