5.5 Bullet parallel conectors
  • MarkF
    dinogylipos.com
    • Mar 2008
    • 979
    Thats a very good Idea. The only thing I would change is to use copper tubbing instead of the brass since it conducts electricity a little better.
    Mark
    • FloatDaBoat
      Bare Bones Fabricator
      • Sep 2009
      • 368
      Mark
      A WHOLE LOT better !!!
      • egneg
        • 4664
        Mark
        No need to over-engineer this as the brass works just fine without any heat due to resistance.
        IMPBA 20481S D-12
        • properchopper
          rcgoatbuild@snotmail.com
          • 6958
          DSC02320.JPGDSC02321.JPGChuck, a big thanks for this idea
          Some 8's I made for a customer :
          • egneg
            • 4664
            [ATTACH=CONFIG]54685[/ATTACH][ATTACH=CONFIG]54686[/ATTACH]Chuck, a big thanks for this idea
            Actually Steven V did it first, all I did was add pictures in a step by step format. Before this I used 8 awg stranded wire but this is much easier.
            IMPBA 20481S D-12
            • Joe007
              Joe
              • 124
              Thanks for all the help here on making the double connection out of the bullet connectors... I went on line and on ebay found Tough Racing out of Seoul Korea, they have the 5.5 bullets with holes though both ends.... I got ten pairs with shrink wrap tubing for like $8.00 shipped to my house... Took less than two weeks to get them...
              • Basstronics
                • 2303
                Heres a new twist...
                HobbyKing 8mm bullets. .155 solid brass rod- right thru the stock holes!
                I made mine to fit the batteries. So I have 2 males/1 female, 2 females/1 male
                • Serpents811
                  • Oct 2011
                  • 381
                  i made a set with cc 6.5 bullets but still havent found heat shrink big enough , help here with that
                  • ron1950
                    • 3024
                    if your heat shrink is close to the size but not quit the right size streatch it with a pair of needle nose plyers...heat will bring it back to size
