Formula For Calculating Speed (Revisited)
  • bbill1
    Tunnelboat Mafia Member
    • Feb 2011
    • 127
    #31
    Originally posted by siberianhusky View Post
    1.4 x 47 = 65.8mm = 2.59"
    what don't you understand?
    Octura props have always been numbered this way, makes it super easy to figure out what you have.
    Not that I didn't understand.
    For nitro I just always used the numbers on the chart. But I got it now. Thanks!
    Current IMPBA P-O/B Tunnel SAW record holder with avg time of 3.358 seconds @ 67.004 MPH.
    Owner Worlds fastest record setting Lynx with average time of 3.287 seconds @ 68.451 MPH.
    Smocktura Props!
    • sailr
      • 7128
      #32
      1.4 is the 'factor' or multiplier. 1.4 x diameter = pitch. Same is true with say a 642 prop. that would be 1.6 x 42 = 67.2mm = 2.645661".
      Originally posted by bbill1 View Post
      How are you guys coming up with your prop pitches? The pitch on a raw x447 is 2.59. Yet in the example below from post #1, it is listed as 1.4.
      I've been into nitro for quite awhile and have never come across any other numbers for pitch other than what would be listed on a prop chart. (in inches and are 2+ inches of pitch for any props I have ever used.)
      Mini Cat Racing USA
      www.minicatracingusa.com
      • BHChieftain
        Fast Electric Addict
        • 2051
        #33
        Thanks again for working this out. This is very helpful. But you need to add a "color" factor to your equation-- we all know red boats go faster...
        Chief
        • properchopper
          rcgoatbuild@snotmail.com
          • 7708
          #34
          Good stuff. One thing, 'tho ( and in no way is this a criticism of these efforts) is that the V or voltage value used is based on the nominal starting V which changes (decreases) considerably under load, as I have found after much data collection/plotting on several brands of batteries. The +/- 3% variation likely is a result, in some part, of this phenomenon. The KV is another possibly varying value based on production tolerance and other considerations.
          • Ub Hauled
            • 3051
            #35
            Tony, I thought about the same thing, but you had to throw a wrench in there, eh?
            LOL
            • carlcisneros
              • Jan 2010
              • 1237
              #36
              good inforamtion all around.
              but, it is a tool for getting an idea of about how fast the boat is going.
              nice to have folks that take time and figure things out for us out in the boating world.
              GOT TO LOVE THIS FORUM!!!!!!!
              • properchopper
                • 7708
                #37
                LOL
                Hey now, I only throw wrenches while working on my chopper - most of the time I throw hockey tape
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2752
                  #38
                  Within 3mph of my GPS reading for my Vegas running 2200KV, X642, 4S. Nice work.
                  • martin
                    • 2881
                    #39
                    Originally posted by Shooter View Post
                    Within 1.7mph of my GPS reading for my Vegas running 2200KV, X642, 4S. Nice work.
                    What speed did you get with gps & from formula. Thanks Martin.
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2752
                      #40
                      Hi Martin.
                      Vegas (X642 S&B, 1515 1Y): (1.6 x 42 x 2200 x 14.8)/33610 = 65mph (GPS = 62)
                      • martin
                        • 2881
                        #41
                        When ever i see someone post speeds with gps & they give relavent info like kv, volts, prop, type of hull i like to work speeds out on how i do it just to see how close or far away i am. With the info on your boat i got 60.8mph. Martin.
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2752
                          #42
                          Martin - Which denominator is correct for Hydro? 33610 or 33300. Both are listed in your first post. Thanks.
                          • martin
                            • 2881
                            #43
                            I dont actually use that formula but either of those numbers work out quite close to one & other on calculated speeds. On say a 60mph boat both those numbers are only .5mph apart. Martin.
                            • penz
                              • Jun 2011
                              • 141
                              #44
                              Hi Martin.
                              So im curious putting that prop on that 1515 motor how are your temps?(motor/esc/batts) What c rating batts are you running, and what esc? I am planing on running a 4074 2150kv motor in my apparition, i am shooting for 50 mph on 4s. If you hitting 65 mph with good temps then i think my setup should work good.
                              LST XXL-4074 Taco, Slash 4x4-3660 Taco, Appparition-3674 Taco
                              • FloatDaBoat
                                Bare Bones Fabricator
                                • Sep 2009
                                • 421
                                #45
                                Here's a spread sheet version (XLS) that I whipped-out.
