water resistant air scoop idea
  • DyrtyByrd
    • 146
    not sure if this is the right place to post this but just wanted to share this idea and see what you guys think of it, its a ventalation scoop for the top of our offshore racers
    sorry for the crappy paint graphics
  • hazegry
    • Jun 2010
    • 815
    its not a bad idea until the boat flips over. why do you need the ventilation?
    • hyrulejedi86
      • Aug 2009
      • 494
      +1 on that!
        • 7990
        Other than the obvious posted above, you need to get the air out once you have it in. With forward-facing scoops only, you will get little air into the hull. You need at least the same area for air to get out as you need for it to get in.
        But I like the idea and it could work well on boats which have little chance of flipping. I tried NACA ducts years ago to keep out water, but they don't work too well scaled down to our size.
        • BILL OXIDEAN
          • Sep 2008
          • 1494
          I've had air intake chines stabalize my boat.
          They werent for ventilation, they were part of the deck structure.
            • 9438
            Use your 3rd channel to open & close a water sealed panel preventing water from coming in if it flips.
            Keep closed all the time, around 3 minute mark open it up using 3rd channel for an few seconds while running and then shut it again. It doesn't take long to vent out the old air and this way the hull stays sealed if you flip it.
            I can't do much for you if you flip it with the panel open.
            I like your idea though!!
            • scoota
              FE DOWN UNDER
              • Dec 2008
              • 409
              i have been working on venting a hatch with a 3rd channel & two micro servos , im testing some switches that that trigger in a roll over , we use a bigger version on our tanker trucks at work in the event of an roll over all power is cut to the truck . but im using it in reverse on the hatch in the event of a flip the servos are powered up to close ..
              UL1- 1515 castle/neu / 240 swordfish
              SV27- with UL1 running gear
              33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
              • dont slow down
                • Feb 2011
                • 120
                I was thinking about using some form of a modified auto bailer, something where when the boat is right side up the ball is down and the tube is open. If the boat flips then the water pressure pushes the ball up or against a seal, keeping the water out.
                Real men have shafts.
                  • 9438
                  Very cool, natural mechanics.
                  • Alexgar
                    • Aug 2009
                    • 3522
                    I did something like this in my fastech with aluminum rams in and out of the radio box of my proboat cost me a mom esc fortunately cc fixed it then I sold it
                    • Simon.O.
                      • 1521
                      I have done something that is similar but without being water resistant !
                      I made the motor compartment in the rigger water proof from the rest of the tub and presto an air cooled OR motor that get a good splash each time it launches.
                      Once I get it setup right the motor may get drip/spray fed water from the esc cooling circuit.
                      see my thread here
                      http://forums.offshoreelectrics.com/...ad.php?t=22903
                      I may even do it to the big Cat !
                      • Boaterguy
                        • 1760
                        I still don't understand the use of this, extra weight, extra air resistance, and to do what? put heavier, cooler air in? I don't mean to sound like a jerk, I just didn't know how to word it.
                        • martno1fan
                          • 238
                          Usual ratio for air in to air out is 1 in 3 out ,so if you have 2 vents with air coming in then you need 6 outlets to let the air out.I dont see the need for it on an electric boat where water cooling is used,only reason we use air vents on gas is to allow the motor to breath,not needed for electrics ......
                          Mart
                          • dont slow down
                            • Feb 2011
                            • 120
                            Well in my case my motors are outrunners and the mounts do not have water cooling, therefore they get pretty hot. So some cooler air inside the hull would do my motors some good.
                            • Boaterguy
                              • 1760
                              I see, I guess with the lack of water cooling some other methods are needed
