Best water pick-up ever!
  • riksorensen
    • Nov 2011
    • 39
    #136
    Originally posted by siberianhusky View Post
    Sorry dude once again fluid dynamics shows that at the speeds we go a sharp square edge to shear the water has less drag, in something like a sailboat a rudder like yours is better as you maintain the laminar flow over the whole length and off the trailing edge.
    Once the high speed water gets past the widest part of your rudder it loses its flow and becomes turbulent as it passes back along the width of the rudder, but it never loses it's contact with the rudder, thus more drag.
    There is an air pocket behind the rudder with a square edge, the water shears off the sharp edge continues behind the rudder and rejoins back behind someplace where it doesn't matter anymore.
    Once again physics.
    Do about a half hour of heading on line and you will find all the info you could ever want about rudder shapes at different speeds.
    The SAW guys have tried just about every rudder shape you could imagine in search of speed, square sharp edges = fast.
    Thanks...
    This is really great info. I just finished wrapping up some research through the tons of info and was kinda shocked at the notion of a square edge in water reacting like this, but it makes sense now especially with how rc boat rudders sit both in and out on the water allowing the air pocket to exist...
    I will re-form the trailing edge to be sharp and square...
    Lovin the physics on this stuff BTW
    Keep the discussion going
    I will post shots of a revised design as soon as I'm done
    Thanks again for the info...!!!
    • riksorensen
      • Nov 2011
      • 39
      #137
      Here are the updated design Pics
      Tapered bottom edge and a square back on it
      Should work great!!!
      Am very open to any further thought or feedback before I polish it up...
      thx
      • millzee
        Ozzie Bloke
        • Nov 2010
        • 1097
        #138
        will that create lift?
        "Gimmy Toyz for FUN"
        • riksorensen
          • Nov 2011
          • 39
          #139
          I am guessing yes,,, but thats why I have a dremel and a sanding block...
          I will test it in May and see what it does...
          It's all a guessing game...
          • Shooter
            Team Mojo
            • Jun 2009
            • 2751
            #140
            I didn't realize this until I tried to lift myself off the ground by my bootstraps while wearing my mobius strip hat. I now stand corrected (and have both a backache and headache from that little experiment)
            Now that's some funny stuff!!! Hat's off!! Unless it's this one....
            • Jeff Wohlt
              • 2740
              #141
              Polishing anything running in the water creates drag or actually does not release the water as fast. Matte finish is better.
              www.rcraceboat.com
              jwohlt5362@yahoo.com
              • madmorgan
                • Jun 2011
                • 152
                #142
                the faster the flow and less restriction in vehicles lets say forklifts in which i work on all the time cools to much especially if we have to open the thermostat because its sticking and we have to order a new one we gut em and it runs to cool sometimes . its a big factor in the propane world because you need to heat the vaporiser err in lamens terms liquid propane flows into a aluminum housing and converts it into vapor and its then sucked into the engine to make it run. if that hot coolant passing through isnt hot enough then the diaprhams etc inside freeze up and it floods the motor because its putting liquid in instead of vapor i have to agree that the faster the flow with least restriction would be more cooling .
                • Cooper
                  • 1168
                  #143
                  On cars you have a closed system, in this application you have an unlimited supply of a stable temperature water supply not glycol ( antifreez) thermodynamics- heat transfer, the speed of water passing through these systems is not interfering in this situation, more water passing through system is very simple, the more heat will be transferred , actually it not transferred, heat is always being absorbed by whatever is of a lower temperature, everything is dissipating it's heat into surrounding, (ultimately to absolute zero, when molecular movement stops) so in these boats more water is better, can't compare to autos
                  • Cooper
                    • 1168
                    #144
                    Hey here is the ultimate example for everyone, how fast is your hot 200 degree motor and speed controller going to cool down to the temperature of the water you are running in if you drip that same water over it say for one hour verses if you throw it into the lake? Is that clear enough? I agree with whoever said if you have the right set up this isn't really an issue
                    • Punisher 67
                      Ignore list member #67
                      • 1616
                      #145
                      Seriously? I thought we put this to bed guys. I'm not sure why this is so difficult to grasp. It's really a rather simple concept. I try to approach this topic without insulting anyone's intelligence, but it becomes difficult after a while. This is one of the oldest redneck theorys out there. I deal with it all of the time and have been listening to people mouth this nonsense for years.
                      Before anyone gets too uptight, Im not calling anyone a redneck. I call this a redneck theory because in my experience that's where it seems to come from in the automotive world.
                      LET ME BE CLEAR...There is only one type of person who believes that "cars run cooler with a thermostat/restrictor plate" crap: Someone who doesn't know cars from their rear end.
                      It's total nonsense. An engine will run coolest at the highest flow rate possible. Before you start to tell me that a car will run hotter with the thermostat removed, do me a favor and go remove your thermostat...let me know how that works out for you.
                      A thermostat is there to allow an engine to heat the coolant to a specified point. It serves no extra cooling purpose at all. It is an element of the cooling system that is in place to SLOW the cooling of the engine until a desire temperature is reached. I really don't know how this isn't obvious unless you just have no idea how a cooling system in an automotive engine works.
                      A restrictor can be used (though very uncommon and often unsuccessfully) to create pressure in a system where an insufficient (wrong) pump is used...but is much more commonly a product of stupidity. There are a lot of reasons people in low level racing use these but the primary one is ignorance.
                      Sorry to rant, but I work in this field and have worked in this field for a long time. It's tough to see the same statement made over and over despite how obviously wrong it is. This is not a subject that can be intelligently debated, because there is no intelligent debate. I thought I provided enough information to put the nail in the coffin on this one, but I guess it will just have to remain a popular urban myth to some people. There is no amount of reality that can can disprove some people's broscience.
                      Well Put Keith , I am surprised this idiotic theory still stands . a thermostat is to regulate heat and not dissipate it . come on guys get real the more cold water pumped through the more heat pumped out .
                      • drwayne
                        • 3012
                        #146
                        I thought this thread was dead ?
                        • Stephavee
                          I like cool things!
                          • 240
                          #147
                          Is it possible to have water cooling lines that are too big? I have some 1/4" od pvc tubing that is thin walled. Will it at some point be harder to push the extra volume of water through the cooling system and stat decreasing efficacy? More cooling water=more weight to push.?
                          " Do you really need anouther boat "
                          YEP!
                          • TristanJones
                            • Oct 2012
                            • 266
                            #148
                            Stephavee, I think you will be surprised at the amount of water the rudder pick ups can provide at 40+mph. I run 4mm ID piping with stock genesis rudder pick up split into 2 circuits with a Y piece for motor/mount and ESC, the water still shoots about 1mtr (3ft) from the side of the boat when I run it above 30mph. I suggest adding an extra pick up if running 2 circuits instead of the Y piece to keep the speed of the water flow up, each time you increase the ID of the pipe U potentially slow down the flow of water, or decrease the pressure in the line.
                            Some very interesting info in here, can't believe there is any argument as to weather more flow of water over the cooling plate will work better or not.... Simple test, get a system that runs hot, hook up a 12v windscreen washer motor to it (3rd channel) and pump water through it with that. Log temps during an otherwise normal run but with the pump on, and then run again with pump removed and a restriction placed in cooling system of boat and check temps (if you even need further convincing after running with the pump on).... Guess what!!! It's cooler with the pump on. (do the test and show video to prove before you argue)
                            To me its common sense, but I've also been working with high performance turbocharged race engines for years. A good debate gets people thinking outside the box which is always a good thing. Hope I haven't come across arrogant here, definitely not my intention.
                            • drwayne
                              • 3012
                              #149
                              You have compromised the cooling effect of the pick up by splitting the flow pathway.
                              Fluid ( water, and likely Ray ) will always take the path of least resistance to the exit...
                              Here, limiting cooling effect on flow bypassed areas. ( I read an earlier thread where your motor was wickedly overheating )
                              Run one line from in to out...
                              burn and learn
                              DocW
                              • dogg
                                • Nov 2012
                                • 49
                                #150
                                Originally posted by don ferrette View Post
                                Actually that's not correct. It is both the amount of water AND the speed in which the water travels. All the water in the world may not properly cool if it does not spend enough time around the object you are trying to cool. This can be done by either restricting the outlet (typically done by the size of the hole on the outlet fitting) to slow the water down or restricting the inlet side to slow the water (the water slows once it passes the restriction) as well as reducing the amount. Controlling the rate of exit is very effective but you need to be careful with too much restriction at speeds over 90 as alot of pressure can build in the lines as a result. On my record trials boats I'll typically restrict both the inlet and outlet using both to achieve the desired temperatures. Using your car analogy going back to when I raced real cars, if you take out the thermostat completely the engine can and usually will actually overheat due to insufficient thermal transfer between the motor and the water. Companies like Moroso make restrictor plates with various size holes that fit in place of the thermostat to help regulate flow rates on race cars. The same goes for the water pumps, we used different sized pulleys to control the speed of water to improve thermal transfer. It is no different with our boats as it is possible to over cool as well as under cool. It doesn't matter if it's nitro, gas of FE powered, all have optimum operating temperature ranges and playing with the rates and speeds of the water will help you get there.
                                I'll probably cop some flak for this as I'm a newbie on this forum; but when it comes to heat transfer in cars, I would like to clarify something...
                                It is a totally different scenario to the one you are relating it to.
                                Firstly the overheating of the motors in cars (be them race or road) without use of the thermostat is NOT due to too much flow through the motor but due to the speed of flow through the radiator being TOO HIGH/FAST to effectively cool it before it re-enters the motor to begin the cooling cycle again.
                                It is however true with an internal combustion motor that too much cooling can cause increased wear and less efficiency with fuel consumption and overall performance.
                                With boats, be them model or full scale (bearing in mind the less efficient and higher wear of internal combustion engines that may result) the fact is that no matter how fast the flow of the water/coolant passing through the motor (water jacket in the case of an inrunner), the higher flow of water will always cool the motor faster and more efficiently.
                                Try cooling your motor with 80 degree water when its running at 130 degrees and it will only ever cool to minimum of 80.
                                Try cooling it with almost freezing point and the minimum possible it can get down to is the same as the almost freezing water.
                                The higher the flow rate, the faster the cooler water reaches the motor replacing the preheated water from the motors water jacket, resulting in better cooling period.
                                I hope I don't offend people with this frank description but I believe this to be true and am interested to know if anyone else finds fault with the logic. I've been in the automotive industry for almost 22 years and have had both road and race cars and this has been my experience and is the only logical explanation in my opinion.
