Building the rear wings
  • Ayles
    • Jun 2021
    • 62
    Since I am new to this I need a few tips or direction to a thread on how to assemble the fiberglass rear uprights and wing from Rc boat company. I have all the parts just not sure how to put the
    together and if there is any framework that goes inside.
    thanks!!
  • Tetefroid
    • Nov 2017
    • 78
    H20.jpg H22.jpg Not my pics but I do it like this also
    • Ayles
      • Jun 2021
      • 62
      That does look nice, I read some threads where one guy used 1/8" aluminum for the mounts but when I got the plate it seems way to thick so I ordered a piece of carbon fiber hopefully that will be more suitable.
      Not sure why that person is using so much more glass mat to reinforce them. They don't seem flimsy at all.
      • 1coopgt
        • Feb 2019
        • 417
        Make sure to put some foam inside of them to make sure they float in case the worst happens.
        • Ayles
          • Jun 2021
          • 62
          I have some half inch closed cel foam from a car restoration I did a while back. Any reason why I couldnt cut it into strips and use it in the wings? Will float and not soak up any water.
          • 1coopgt
            • Feb 2019
            • 417
            That should work good.
            • RandyatBBY
              • 3915
              https://www.ebay.com/itm/35384600591...evt=1&mkcid=28
              this is the best floatation for feathers and wings.
              I realy liked the aluminum rods from RC Boat works ran at a 45degree angle from center to wing.
              Randy
              BBY Racing
              • 1coopgt
                • Feb 2019
                • 417
                https://www.rcboatcompany.com/wings-parts
                It would be nice if the Rod kit was available. I've been waiting for them for a year now to become available.
                • RandyatBBY
                  • 3915
                  After I bought it once I have built my own since then. I do not use the big plate in the middle just ball links to the transom. I use break away tooth picks in the feathers to deck mounts. all the rest of the parts come feom Dubro.
                  Randy
                  BBY Racing
                  • Ayles
                    • Jun 2021
                    • 62
                    As far as the support kit goes, I have been on the list to buy one for several months. Apparently the guy that makes the bracket on the transom has been ill.
                    • Mike W
                      • May 2018
                      • 348
                      What retains the toothpicks?
                      Otto RC Marine
                      • RandyatBBY
                        • 3915
                        What I do is when you drill your holes use a 3/32 drill bit. Get round tapered Tooth picks. Take one in each hand and from each side of the feather push the tooth picks intill they stop, you have to push hard to wedge them in. then use wire cutters and clip each side. Then do the other three holes the same. They will stay in the wing untill a crash, they will break away no harm to the Feather or mount.
                        Randy
                        BBY Racing
                        • 1coopgt
                          • Feb 2019
                          • 417
                          I'm planing on using 4-40 nylon/plastic hardware to mount the wings. I pressed 4-40 pem nuts into the carbonfiber mounting tabs on my boat.
                          • RandyatBBY
                            • 3915
                            That might work , It might also rip the wing or damage the paint
                            Randy
                            BBY Racing
                            • 1coopgt
                              • Feb 2019
                              • 417
                              Not quite sure how it would rip the wings or damage the paint. But stranger things can happen i suppose. I won't be racing the Hydro, no clubs around here. The plastic or Nylon screws are pretty soft and will snap. 4-40 screws aren't very thick. These were recommended by the folks over at Inlwaters.com . Very knowledgeable folks over there when it comes to Hydros.They tend to specialize on Hydros from going through the forums over there. Kind of like Offshoreelectric.com tends more towards Cats and Mono's
