Cable size
  • G.Rose
    • Apr 2010
    • 874
    Cable size
    I am building a 1/7th scale hydro. Would a 3/16th cable be to small? Or should I use a 1/4" flex with a 3/16th stub. 1/4 flex is so heavy. 55" CF boat 13lbs, 1527 1.5/Y NEU or Scorpion both 850 kv
    Gary
  • photohoward1
    • 1781
    go with the 1/4"
    • Doug Smock
      • 5359
      Originally posted by photohoward1 View Post
      go with the 1/4"
      What he said..
      And I learned the hard way a few years ago to use a 1/4" dog so that you don't weaken the 3/16" stub putting a flat on it.
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
        The 1/4” cable is 75% heavier - but really that’s just a few ounces. You will thank us when your hydro isn’t stuck dead in the middle of the pond with a broken cable, taking on water with no rescue in sight…
        Depending on the props you will use, there is more strength using a 1/4” bore prop. Those motors will handle the smaller 1/4” props - on 8S.
