10S classic thunderboat 1/6.6 scale electric conversion
  • jingalls007
    • 1172
    It’s a T2 Insane hull. 59” long by 25” wide.
    Whoa.. that's a big boat. Or did you mean to say 49"? Either way it's a BIG boat!
    I might have to make a trip back home to CO to run with you and the gas dudes a time or two.
    • Jesse J
      scale FE enthusiast
      • 7818
      Um... ya 49” long ... c’mon back!
      "Look good doin' it"
      See the fleet
      • Dr. Jet
        • 1759
        .......... Also, anybody have a great idea on how to make the tail fin? Debating whether to make strongly attached, or more of a break away...
        What about making it removable/replaceable? That would serve double-duty as a break-away. Embed some tubes in the aft cowl and deck, then embed some protruding music wire/CF rods in the fin........
        A nation of sheep breeds a government of wolves
        • Jesse J
          scale FE enthusiast
          • 7818
          Good suggestion, I’ll play with that. Thanks!
          See the fleet
          • Jesse J
            scale FE enthusiast
            • 7818
            Let there be white, get reddy
            Painted some today..
            Still waiting on 3D engine to finish front hatch and mono Jeff for graphics.
            See the fleet
            • jingalls007
              • 1172
              Looks marvelous!
              • Jesse J
                scale FE enthusiast
                • 7818
                Stripes? Electrical tape and 1/8? white trim tape.. and 3.5 hrs of time..
                See the fleet
                • jingalls007
                  • 1172
                  What type of paint did you use?
                  I?m debating rattle cans and 2k clear but not sure I have your skills Jesse.
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    Duplicolor automotive rattle can paints are amazing!
                    The white is a pearly matte, and then nice racing red. Then I did a metal flake topped by clear coat.
                    The green is krylon. Just be sure to scuff every square millimeter! Because when you remove the masking tape, you’ll find where you missed!
                    Definitely avoid rustoleum!
                    See the fleet
                    • jingalls007
                      • 1172
                      Great work, jesse! That checkered/striped pattern came out fantastic! I'll grab duplicolor rattle cans.
                      Will you clear it with 2k or something similar?
                      • Jesse J
                        scale FE enthusiast
                        • 7818
                        Any ideas on materials for the fin? Foam board or other light weight strong board material that floats?
                        See the fleet
                        • eric113
                          • Sep 2011
                          • 327
                          What if you used some type of foam board then cover it either wood or FG?
                          • Jesse J
                            scale FE enthusiast
                            • 7818
                            You have a foam board link to go with your tboat owner recommendation?
                            See the fleet
                            • eric113
                              • Sep 2011
                              • 327
                              You can order foam board on amazon.
                              Something that came to mind, call Steve at rc boat company, maybe he will willing to make you fin?
                              • Dr. Jet
                                • 1759
                                Plywood over a built-up balsa core. You can easily add internal tubes for attachment rods. "Glass the whole thing when done. Light and strong.
