ferarri hydroplane
  • cut boat
    • Jun 2020
    • 11
    ferarri hydroplane
    hi, im in the uk living full time on a narrowboat, i have a Ferrari boat that i would like to restore, when it was running it always seemed to under perform so i thought id come and ask some experts as we seem to be years behind you guys.....
    is it a kit or scratch build? i would like to make it quick and handle if possible it was always quite slow......it is 30 long..12 wide....prop is 30mm...brush less motor is 30 mm prop is 30mm..3mm prop shaft..speed control is Apollo 25 2-6 lipo.. would you please tell me what brushless motor,esc,prop and battery i need
    thanks in advance
  • Jesse J
    scale FE enthusiast
    • 7818
    Dang, what kit/model is this? I’d love to make one of these!
    "Look good doin' it"
    See the fleet
    • cut boat
      • Jun 2020
      • 11
      hi, im not sure to be honest,iv had it ten years.i bought it at a club rc boat jumble....its made out of ply wood and looks hand cut...this is all i know about it
      • Jesse J
        scale FE enthusiast
        • 7818
        Wow, well.. welcome to the forum!!
        What are your goals? Race or fun? If race what class? If fun what speed?
        We can help you with these questions answered.
        See the fleet
        • jfrabat
          • Apr 2020
          • 110
          That is one sweet looking boat!
          • cut boat
            • Jun 2020
            • 11
            hi, iv stripped the hull out and started sanding, there are a few thin bits and some hole, which west system product do you advise?
            • 785boats
              Wet Track Racing
              • 3423
              Is the canopy carved from solid wood?
              If so, it looks like it may be one of the static display models made in Vietnam, similar to the one that I bought & converted to R/C.
              However the one I bought was 38" long.
              Could you clarify what size & kv the motor is please? It is not really clear from your description in the first post.
              • golfito
                • Sep 2011
                • 302
                Hello, it is a very beautiful boat. Can it be an Amatti kit ?, or at least the fuselage.
                Ferrari Arno XI 1:8 scale, laser-cut wooden hull to be assembled, double planking and additional components included in the kit. Suitable for radio control.
                That fuselage is a model that I would like to build. I can't afford to buy that Amati kit. But soon I will try to reproduce it.
                I recently finished building one of the same family:
                And I'm on my second construction with a different plane:
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  Golfito, are those kits you build?
                  See the fleet
                  • golfito
                    • Sep 2011
                    • 302
                    Hello, no, they are not kits.
                    In the first photo I used Gary Finlay's plans as a base. Wood cut to saw. The Ferrari fuselage was built under a blueprint supplied to me.
                    The second photo, I used the plans that accompanied the Ferrari fuselage, that if laser cutting was used.
                    And I look forward to an Arno XI fuselage, also a visible V12 engine ...
                    I have the construction and plans published in another forum if you are interested. They are my first constructions, I try to gather information and knowledge about these boats.
                    If you want more information about the plans, we will contact you.
                    Regards.
                    • 785boats
                      Wet Track Racing
                      • 3423
                      A bit of inspiration for you.
                      • cut boat
                        • Jun 2020
                        • 11
                        thanks for taking the time, i will get some pics of the progress in an hour or so...have ordered all the parts now
                        • golfito
                          • Sep 2011
                          • 302
                          Beautiful video.
                          I'm still undecided. I already have an Italian model. I also like the American boats from the '50s.
                          Waiting for photos of progress, she is a beautiful model.
                          • cut boat
                            • Jun 2020
                            • 11
                            [ATTACH=CONFIG]169948[/ATTACH]
                            • cut boat
                              • Jun 2020
                              • 11
                              Hi, .iv replaced some of the bottom of the boat were the old shaft came through the hull then used 17g fibre glass cloth and west system to strengthen and water proof the hull,then sanded back and grey primered...the deck has been sanded and a piece fitted at the bow to replace some damage .....the upper part is plastic had split along the length so have repaired that and made it all one piece. I plan to use a hidden water tight deck to stop ingress of water and sit the top over that.....if ordered a 3660 water cooled motor 2000kv ..4mm flexi shaft and a 38mm two blade prop....how fast should it be with this set up?20200703_045710.jpg20200703_045615.jpg
