Need help
  • Vin-m
    • May 2014
    • 308
    Need help
    I'm running a hydro w a etti hv esc and a neu 1527 1.5y motor octura 450 prop on 10 cell and the boat revs out w no load but when I put it in the water for the first time today it can't Rev up.... If I hold the prop out of the water then pull full throttle and hold it, then drop the boat into the water it'll take off like a rocket and hold speed until I let off the throttle. Once that happens it can't Rev out again when the throttle is pulled again. I have tried changing the low voltage cut off from the 10 cell setting to disabled. I have tried changing the timing of the motor. I have tried changing the pwm settings. On the telemetry there is no large voltage spikes. Nothing seems to work. The batteries are brand new. Any ideas fellas?
  • jingalls007
    • 1172
    What boat is this? Is there space between your drive-dog and the strut? Etti 220 HV? Is your collet tight?
    • Vin-m
      • May 2014
      • 308
      It's a hydro and marine hull. There us space between the drive dog and strut. Collet is tight. And it is an etti 220hv.
      • jingalls007
        • 1172
        Did you set the throttle endpoints on the ESC? Which H&M Hydro?
