Motor Rotation 1/10 Scale Hydro
  • klloyd67
    • Jun 2017
    • 55
    When I ran 1/8 Scale nitro we ran with left rotation when looking at prop from transom. Do 1/10 scale FE guys do the same thing?
    Thanks,
    Kevin
  • JimClark
    • 5913
    They turn left and use right hand props
    Billy Graham
    • klloyd67
      • Jun 2017
      • 55
      So I need a right lay flex cable?
      Sent from my VS985 4G using Tapatalk
      • TRUCKPULL
        • 3293
        YES
        Larry
        • leonard feeback
          • 130
          Offshore Electric has both flex shafts and props needed for 1/10th scale.
          • klloyd67
            • Jun 2017
            • 55
            Question?, if the brushless motors can rotate left or right and there are more prop options for left rotation, why wouldn't I run left hand?
            • JimClark
              • 5913
              There used to be only a couple of RH props that would work but there are now quite a few to choose from. When the 1/10th scale first started in Seattle it was a bunch of Hydro Geeks that wanted to mimic the real Unlimited's and they turn left.
              Billy Graham
              • TRUCKPULL
                • 3293
                If you want to run with the 10th class and turn left. You want a right hand prop.
                If you run a left hand prop, you boat will not like it (very hard to turn left when spinning a left hand prop.
                The prop walk helps the boat turn.
                Larry
                • klloyd67
                  • Jun 2017
                  • 55
                  Thanks, little slow on hydro physics
